How long is too long?
Old Jun 12, 2025 | 12:24 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I’m doing the 0411 pcm swap with one coil per plug. I not putting the coils on the valve covers but want to put them up front on either side of the radiator. I’m concerned about the pink/black power wire running from the C207 being too long to the coils on the driver side and overheating. I measured roughly 11 feet from the C207. I know that wire also feeds 4 of the injectors too. Is that too far? Those wires running from a 15 amp fuse.
Old Jun 12, 2025 | 02:25 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: How long is too long?
Originally Posted by Duane's 91 Z/28
I measured roughly 11 feet.
well thats the neat thing about tuning, you can add more timing to take up the slack
also, dont forget, electricity travels pretty fast..
Old Jun 12, 2025 | 06:53 PM
Car: 1991 red Z/28
I did some research on some different electrical wire sites and I think I'm safe as I'm seeing 12 volts and 15 amps going through 50 ft of wire without any problems. I just don't know how much power draw those coils pull is my biggest concern.
Old Jun 12, 2025 | 09:03 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
I did some research on some different electrical wire sites and I think I'm safe as I'm seeing 12 volts and 10 amps going through 50 ft of wire without any problems. I just don't know how much power draw those coils pull is my biggest concern.
What coils are you using?? A set of LS coils??
Old Jun 12, 2025 | 09:27 PM
Car: 1991 red Z/28
Yes I am using LS coils. I corrected my last post to 15 amps from 10 amps after seeing Pockets diagrams. 10 amps were only for the injectors, not with coils. The wires from the C207 are 16 gauge, correct?
Old Jun 16, 2025 | 12:04 AM
Pocket's Avatar
Car: 91 Trans Am
18ga, but there's nothing stopping you from running larger
Old Jun 18, 2025 | 09:56 AM
Car: 1991 red Z/28
After I looked at them I realized they were 18ga. That pink ign wire, why can’t I put an inline fuse on it? Or what 10ga wire could I splice into so I can get power to the coils at the front of my car?
Old Jun 18, 2025 | 12:25 PM
Pocket's Avatar
Car: 91 Trans Am
I upped the INJ fuses to 15a. Never had an issue
Coils on the same wires, 18ga
Why are you wanting 10ga for?
Old Jun 18, 2025 | 05:13 PM
Car: 1991 red Z/28
I was worried about the extra length. I’m putting the coils up on either side of the radiator instead of over the valve covers. I’m just trying to be cautious.
Old Jun 19, 2025 | 07:49 AM
Pocket's Avatar
Car: 91 Trans Am
Putting 10ga in will not change the fuseblock to C207 run still being 18ga
If you think it's too long, then add a relay and use the old fuse wire to trigger them
Old Jun 19, 2025 | 09:56 AM
Car: 1991 red Z/28
Okay I will keep the 18ga wire, put a 15amp fuse, and get a relay and put it inline somewhere. Thanks Pocket. Much appreciated . I’m sure I will have more questions later.
Old Jun 19, 2025 | 10:14 AM
thatsupnow's Avatar
Why do you want your coil packs up by the radiator?? They're not gonna get fatigued by heat as they're designed to handle it all and the plug wires are gonna be ridiculously long
Old Jun 19, 2025 | 10:21 AM
Car: 1991 red Z/28
I just don’t want them on the valve covers. I’m not sure where else I could put them except possibly under the engine and there isn’t much room for them underneath.
Old Jun 19, 2025 | 10:25 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
I’m not sure where else I could put them.
im goign to mount mine in the cowl. i dont have wipers
Old Jun 19, 2025 | 10:51 AM
Car: 1991 red Z/28
I do have wipers. I think I’m going to modify the aftermarket coil bracket I bought and put the coils underneath. The starter side is going to be harder to figure out.
And that’ll eliminate the long wire problem.
Old Jun 20, 2025 | 10:17 AM
Pocket's Avatar
Car: 91 Trans Am
Mount them on the frame rails right next to the exhaust?
Old Jun 23, 2025 | 08:00 AM
Car: 1991 red Z/28
I might give that a try. I have a manual tranny so I should have a little room there.
Old Jun 28, 2025 | 09:01 PM
Car: 1991 red Z/28
I made a shelf for the 0411 PCM where the battery was. I also am putting the fan relays under it and have plenty of room for the wires. Next I will get the coils under the car next to the transmission.
Last edited by Duane's 91 Z/28; Jun 28, 2025 at 09:06 PM. Reason: added a sentence
Old Jun 28, 2025 | 09:24 PM
thatsupnow's Avatar
That's wild you'd put the coils in an area that will see a form of punishment. I get it that it's your car and you can do whatever you want but at what point do you sit back and be like "is this a smart idea?" That's probably the worst placement I've ever heard of. But nobody here is gonna stop you from learning the hard way
Old Jun 29, 2025 | 10:27 AM
Car: 1991 red Z/28
I'm going to make a little splash cover for them so they'll be fine. But thank you for your input to this matter.
Abubaca
Aug 8, 2016 07:18 PM
BOSS 357
Apr 2, 2009 09:54 PM
vorgath
Car Audio
Dec 6, 2005 04:45 AM
83_Camaro_83
Car Audio
24
Jan 7, 2005 05:44 AM
85TPITransAM
Car Audio
Apr 7, 2003 03:18 PM
