Engine don't stop with key ....
Old Dec 2, 2025 | 12:30 PM
newell63's Avatar
Hi everybody.
Sorry for my bad english.
I have a 83 Z28 305ci, i rebuild this car which was a mess.
One day i start the engine to move the car and surprise when i turn off the key the motor don't stop....i try to unplug the battery but still running, so i have to block the air filter to suffocate the engine.
Everything work before and now i can't stop engine.
What do i need to chek (i'm noob in electricity) ?
Can someone help me ?
Thanks a lot to everyone !
Old Dec 2, 2025 | 12:43 PM
Re: Engine don't stop with key ....
How is the distributor connected? (specifically, its power)
Old Dec 2, 2025 | 12:52 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
It shouldn't run with the battery disconnected...
Old Dec 2, 2025 | 01:14 PM
newell63's Avatar
With 2 pins, i take picture as soon as i can.
Thanks for answer
Old Dec 2, 2025 | 02:20 PM
Sure it should. That's been the test of generators and alternators since they were invented: if you unhook the batt and the car dies, the generator isn't generating. NOT A Good Idea to use that troubleshooting method on cars nowadays, with all the electronics; but the principle remains the same.
When I asked "how is it connected", I was more asking, what is its source of power. It also might be worthwhile to disconnect the small plug going into the alternator and see if it turns off normally then.
Old Dec 2, 2025 | 07:02 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Unplug the 12v wire to distributor. That should kill it until you find the issue
Old Dec 3, 2025 | 04:31 AM
newell63's Avatar
I'll try to disconnect the small plug .
The ignition Switch on the steering column might be the problem ?
Another weird thing, the choke light (left to engine light) is Always on when key is off position , and the light shut down when Key is on position, we have manuel starter, so it's normal or not ?
Many thanks
Old Dec 3, 2025 | 06:04 AM
Doesn't sound like the ignition switch. It could be, but not likely.
No that "choke" light behavior is not right. It makes no difference whether the car has a manual transmission or an automatic.
The "choke" light is ACTUALLY the "alternator" light. The regulator, inside the alternator, lights it, when the key is On and the alternator is not generating electricity, via that small plug. The reason it's labelled "choke" is because the choke, which is electrically heated, gets power only when the alternator is charging; this prevents it from getting heated when the key is on but the engine is not running. When the alternator doesn't work, then the choke doesn't get power, and it stays in its "cold" setting permanently, which makes the engine run VERY rich, which creates VERY high pollution; and evidently the factory chose to warn the car's operator about THAT condition (the choke warm-up being disabled), instead of telling what's REALLY wrong, namely, the alternator not working.
Again, try disconnecting the small plug going into the alternator, and see what happens.
sansui
Aug 7, 2024 08:11 PM
McGregord7
Aug 20, 2012 03:03 AM
kbomb84rs
Aug 21, 2008 05:02 PM
Bri87GTA
May 23, 2006 08:12 PM
Connan1
Dec 24, 2003 09:20 PM
