Complete Manual t-5 Conversion for trade!
Old May 9, 2006 | 11:26 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
For Trade:
1 '86 NWC T-5 miles unknown but I have driven it and found it very reliable.
1 hydraulic bellhousing
1 aluminum slave cylinder
1 SS braided slave cylinder line w/ mcleod fittings
1 Brand new still in box Duralast clutch w/ lifetime warranty
1 used flywheel still very good!
1 Shifter and all hardware
* You may get the pedal and master cylinder but You will pull it off the car yourself I do not have time for this, but I assure you this is a complete and nice trade.
Here is what I want.
A complete 700 R4 Conversion... including flex plate, Torque converter, cooler shifter everything... I am giving alot so this should be in very good condition and clean as all my parts are clean.
** I am also looking for a 350 core, shortblock or longblock!!**
This is for trade in the savannah area, you can pick up I will not ship.
Old May 9, 2006 | 08:04 PM
klumb15's Avatar
if you sell the trans, and are looking for a built 700r4, i have one with less than 200 miles. I just swapped to a built T-5 myself, so I have no use for it. I'm asking $750 for it if your interested...
Old May 9, 2006 | 08:41 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
im interested... are you in savanah GA? im in middle GA and i have been wanting to do the swap. i will have all the auto stuff left over if you want to just trade out.. lmk something im interested.
Old May 10, 2006 | 04:08 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Miles and condition?
I need every single nut and bolt I need to convert manual to auto.
I also do not want to screw myself in this deal and make sure the trade is an even one. I do have a few new parts such as the slave cylinder and ss braided line with the special fittings, and new clutch. Anyone help me with the what is worth what? I do not want to screw anyone over and vise versa. I have noticed these swaps going for atleast $500-650+ Not looking for money just a replacement trans and 350 core or shortblock etc..
Old May 12, 2006 | 06:34 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Still up for grabs!
Old May 12, 2006 | 09:41 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I have what your looking for, and it sounds like you have what I need. The only problem is I am in Peoria, IL. My car is a 91 GTA. The transmission has about 1500 miles on it at the most. I had it built at Pioneer Parkway Transmissions in Peoria. It has just about every upgrade available for the 700R4, and the case is painted.
I have a good amount of money in it, but I have really been wanting a manual since I have started autocrossing, my Subaru(it has a manual). I have not been able to find a complete package deal, so to this point I have not had the motivation to pull my car apart.
If we did this I would be interested in the pedals and the center counsel plate. Of course I would offer you my pieces in return. I really do not want to search for parts so I would also be interested in a complete swap. Truth be told I probably will not even use the trans, just all the hardware. I probably need a TKO, if I want it to last.
Hope we can work something out.
Old May 13, 2006 | 04:29 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I am very interested in what you have to offer, the distance however is a bit of a problem. I am sure we can work this out somehow.
Old May 13, 2006 | 07:58 PM
Car: 88 IROC
nelapse im still interested i sent you another pm.
Old May 25, 2006 | 06:19 PM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
i need flywheel clutch and bellhousing my 700r4 has 36521 on it im in st louis
Old May 30, 2006 | 03:38 AM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
85blackberlinet i need flywheel clutch and bellhousing my 700r4 has 36521 on it im in st louis i have the flywheel clutch and bell housing and need a 700r4 ml258@yahoo.com
Old Jun 1, 2006 | 10:29 PM
Car: 85 berlinetta
Engine: none
trying to find someone within driving distance so little down time
Old Jun 13, 2006 | 08:15 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
This item is still up for trades....
Old Jun 15, 2006 | 11:30 PM
IROCmenace's Avatar
Car: 1988 IROC
Transmission: 700R4 Silver Dart
Axle/Gears: 3.70 posi
I have a 350 that ran when pulled. It is a late 70's motor.
What kind of deal did you want for a 350 core?
I'm 30 miles South of Nashville.
Last edited by IROCmenace; Jun 15, 2006 at 11:31 PM. Reason: Automerged Doublepost
Old Jun 19, 2006 | 04:26 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
I have an 89 IROC with 700r4 I'll trade for your t5. I'm in Huntsville AL so I could bring/pick up parts. We'll swap every nut, bolt, trim piece etc. How's this sound?
The trans is in my daily driver. It has a shift kit and works fine. I'd need to know we got a deal before I pull parts. Let me know.
Old Jun 20, 2006 | 01:49 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
i would love too but it all depends on how long it will be before i see it... how long we talking about here....?
Old Jun 20, 2006 | 10:49 AM
Car: 89 IROC
Engine: 6.8 HSR N2O
what you doing over the forth?
Old Jun 21, 2006 | 11:22 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I have duty on the fourth and work the day after... however nothing on the 3rd... The week after that I have completely off... PM me your phone number so perhaps we can get a better hold on this
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
