holley 850 cfm double pumper
Old Aug 25, 2006 | 05:55 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Selling a 850 cfm double pumper holley carb. This is the style that doesn't have a choke tower. Too big for my motor so I'm switching to a 750 instead. Carb is clean with new gaskets in it. Primaries have been drilled 1/8" to try to get carb to idle on my motor, but can easily be epoxy'd shut if/as needed on your combo. Carb also has the quick fuel secondary pump cam on it so you can adjust secondary opening from the top instead of taking the carb off and on all the time. Carb has two power valves and lists for $469.00 through jegs without the quickfuel kit which was another $30, so $500 total new. I'm taking a loss on this since I need to buy another carb quick.
$300, cashiers check, money order, or personal check being held until it clears...7-10 days sometimes.
Old Aug 26, 2006 | 11:40 PM
xpndbl3's Avatar
Car: 1984 Z28
TTT
Old Aug 28, 2006 | 11:43 PM
xpndbl3's Avatar
Car: 1984 Z28
willing to trade for interesting items as well. tubular pieces, nitrous kits, etc
Old Aug 29, 2006 | 06:09 PM
Groundczero's Avatar
Would you trade for a NOS Cheater kit with regulator?
Old Aug 29, 2006 | 10:35 PM
xpndbl3's Avatar
Car: 1984 Z28
is the kit complete? spray plate, solenoids, wiring, microswitch, bottle, lines, etc etc etc. If so then yea i'd consider it assuming everything works properly.
Old Aug 30, 2006 | 08:55 AM
http://fitscc.fit.edu/album_pic.php?pic_id=901
The kit does not come with wires, or the micro switches, cause I would not re-use the electronic stuff, but the solenoids are one bottle away from new.
And it comes with fuel regulator and guage wich is more than the wires and electronics are worth.
Old Aug 30, 2006 | 01:42 PM
xpndbl3's Avatar
Car: 1984 Z28
that's fine I'll trade for that kit. Do you have the bottle brackets or any jets for the nitrous kit? I can PM you my address and upon receiving the nitrous kit, I will ship out the carb through UPS with a tracking number for you.
Old Aug 30, 2006 | 02:27 PM
I have the bottle bracket. I would rather we ship the items the same day, wich I can do tomorrow then wait till you got the Nitrous and then you send me the carb if that is acceptable.
Old Aug 30, 2006 | 02:31 PM
xpndbl3's Avatar
Car: 1984 Z28
since you're a new member I'd rather receive the nitrous kit then ship out the carb. You can check me out since I've been on the boards for over 4 years now, I plan parts of the thirdgenfest gathering every year that has it's own board, I also am active on the chicago board in planning events, so I'm trustworthy. I will PM you my address and upon receiving the kit I'll send out the carb with tracking info PM'd to you through UPS. thanks.
Old Aug 30, 2006 | 03:54 PM
Ok, I am gonna go on your word, please get me your address tonight, so I can send it out tomorrow, cause I will be out of town till next tuesday after that.
Old Aug 30, 2006 | 04:06 PM
xpndbl3's Avatar
Car: 1984 Z28
I already sent out the address through a PM and a e-mail to you. thanks again and I'll let you know when the nitrous kit arrives and get your carb out to you.
Old Sep 5, 2006 | 09:51 AM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
its a long shot but if that falls throught i can come pick it up...
Old Sep 6, 2006 | 12:03 PM
xpndbl3's Avatar
Car: 1984 Z28
deal pending....so we'll see.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
okfoz
Oct 13, 2015 02:19 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
Dragonsys
Sep 25, 2015 03:51 PM
