90 camaro preformance and engine/transmission parts PICS!!!
Old Aug 27, 2006 | 12:11 PM
HuggerI-ROC's Avatar
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
Hi, All
Well I turns out I am Collage bound, and since this became a project and it’s in my
fathers garage he wants everything out before I go. Here is a quick list of what I
have managed to remember and I’m sure I all be adding some stuff later on.
All prices do not include shipping, feel free to e-mail me at jnreilly@sbcglobal.net
For a quote. As always I hope the big stuff with go to local buyers. So again feel free to
Come pick-up anything if your in the Houston area.
I prefer Paypal but M/O and check are fine as well.
Willing to take all most anything for them, just PM me
Pro Topline Heads, completely assembled, for a small block Chevy. They have been completely remaned by and ASE master machinist. They have been baked at 625 degrees and shot peened. Following that they have been magnufluxed to ensure they are no cracks, none found. Then the studs were installed. Both gaskets surfaces have been milled to ensure proper sealing, the intake only had .004 taken off. The valve guides were then reamed .015OS and the seats were cut with a three angle cutter. The firedeck has been milled .012. the heads were then washed and assembled. The valves are 1.94 and 1.50, they have dyno time on the valves only. The springs are new as are the retainers and the locks, they are .030 higher Comp. than factory. The valves seals are Vitron umbrellas. The chamber CCS are around 68 and I am insure of the runners, I believe they are 180 but not positive
$425
more
<table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"><col> <tbody><tr><td style="height: 12.75pt; width: 295pt;" height="17" width="393">T-5 transmission setup with spec stage 1 clutch
</td> <td class="xl24" style="width: 54pt;" x:num="500" width="72"> $ 450.00
</td></tr></tbody><col style="width: 54pt;" width="72"><tbody><tr style="height: 12.75pt;" height="17"></tr> </tbody></table>
Old Aug 27, 2006 | 12:28 PM
<table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"> <col style="width: 54pt;" width="72"> <tbody><tr style="height: 12.75pt;" height="17"> <td class="xl24" style="height: 12.75pt; width: 295pt;" x:str="Chevy Camaro 82-92 ZENN lowering springs 1.7&quot; F&R " height="17" width="393">Chevy Camaro 82-92 ZENN lowering springs 1.7" F&R </td> <td class="xl25" style="width: 54pt;" x:num="99" width="72"> $ 99.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl24" style="height: 12.75pt;" height="17">KYB GR-2 SHOCKS CHEVY CAMARO & FIREBIRD 82 - 92</td> <td class="xl25" x:num="99"> $ 99.00 </td> </tr></tbody> </table> <table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"><col> <tbody><tr><td style="height: 12.75pt; width: 295pt;" height="17" width="393">orange jegs seats with Org/Blk covers & rails
</td> <td class="xl24" style="width: 54pt;" x:num="135" width="72"> $ 130.00
Old Aug 27, 2006 | 12:33 PM
<table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"><col> <tbody><tr><td class="xl24" style="height: 12.75pt; width: 295pt;" x:str="CHEVY 305 350 454 MINI STARTER SUPER TORQUE ST100 " height="17" width="393">CHEVY 305 350 454 MINI STARTER SUPER TORQUE ST100
</td> <td class="xl25" style="width: 54pt;" x:num="70" width="72"> $ 70.00
</td></tr></tbody><col style="width: 54pt;" width="72"><tbody></tbody></table><table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"> <col style="width: 54pt;" width="72"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 295pt;" height="17" width="393">new spark plug wires</td> <td class="xl24" style="width: 54pt;" x:num="0" width="72"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">new distributor cap</td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl25" style="height: 12.75pt;" height="17">MSD Blaster Coil</td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl26" style="height: 12.75pt;" height="17">total</td> <td class="xl24" x:num="55"> $ 40.00 </td> </tr></tbody></table>
Old Aug 27, 2006 | 12:38 PM
<table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"> <col style="width: 54pt;" width="72"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 295pt;" x:str="GM TBI 2&quot;/50mm bore1987-95 SBC intake " height="17" width="393">GM TBI 2"/50mm bore1987-95 SBC intake </td> <td class="xl24" style="width: 54pt;" x:num="0" width="72"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:str="454/350 GM TBI 50mm SBC tbody-750cfm " height="17">454/350 GM TBI 50mm SBC tbody-750cfm </td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">NEW High Flow like Walbro 190 TBI Fuel Pump</td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">New Ajustable fuel pressure regulator</td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:str="GM 454/350 TBI injectors " height="17">GM 454/350 TBI injectors </td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:str="F-body TBI INJECTOR SPACER V6, V8 " height="17">F-body TBI INJECTOR SPACER V6, V8 </td> <td class="xl24" x:num="0"> $ - </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl25" style="height: 12.75pt;" height="17">total</td> <td class="xl24" x:num="500"> $ 500.00 </td> </tr></tbody> </table>
<table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"> <col style="width: 54pt;" width="72"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 295pt;" height="17" width="393">A/C pump</td> <td class="xl24" style="width: 54pt;" x:num="30" width="72"> $ 30.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td class="xl25" style="height: 12.75pt;" height="17">a/c condenser</td> <td class="xl24" x:num="30"> $ 30.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" x:str="82-92 CAMARO A/C DELETE PULLEY " height="17">82-92 CAMARO A/C DELETE PULLEY </td> <td class="xl24" x:num="40"> $ 40.00 </td> </tr></tbody> </table>
<table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"> <col style="width: 54pt;" width="72"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 295pt;" height="17" width="393">truck lifters</td> <td class="xl24" style="width: 54pt;" x:num="25" width="72"> $ 25.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">brand new P/S pump</td> <td class="xl24" x:num="45"> $ 45.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">A/C pump</td> <td class="xl24" x:num="20"> $ 20.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">accessory bracket</td> <td class="xl24" x:num="35"> $ 35.00 </td> </tr></tbody> </table> <table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"><col> <tbody><tr><td style="height: 12.75pt; width: 295pt;" height="17" width="393">coolant overflow container
</td> <td class="xl24" style="width: 54pt;" x:num="8" width="72"> $ 8.00
</td></tr></tbody><col style="width: 54pt;" width="72"><tbody></tbody></table><table x:str="" style="border-collapse: collapse; width: 349pt;" border="0" cellpadding="0" cellspacing="0" width="465"> <col style="width: 295pt;" width="393"> <col style="width: 54pt;" width="72"> <tbody><tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt; width: 295pt;" height="17" width="393">305 shortblock</td> <td class="xl24" style="width: 54pt;" x:num="200" width="72"> $ 140.00 </td> </tr> <tr style="height: 12.75pt;" height="17"> <td style="height: 12.75pt;" height="17">305 heads</td> <td class="xl24" x:num="150"> $ 99.00 </td> </tr></tbody></table>
Old Aug 27, 2006 | 12:42 PM
Thats all for now.
other threads
interior: https://www.thirdgen.org/forums/inte...90-camaro.html
exterior:
https://www.thirdgen.org/forums/exte...90-camaro.html
Remember I'm in Houston and anyone who is interested
all be in around Austin next week so drop me a line if you
want something.
Thanks, JR
Old Aug 27, 2006 | 12:46 PM
double post @_@
Old Aug 31, 2006 | 11:46 AM
TTT
Old Sep 1, 2006 | 03:00 AM
Pat Hall's Avatar
pm sent....
Old Sep 12, 2006 | 02:39 AM
I have to apologies for my rudeness for not replying to PM latly, I have had a big side track that started with Labor day and ends with me buying a 1st Gen (84) Mazda RX-7 with a Chevy 305 in it. <!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" alt="" style='width:12pt; height:12pt'> <v:imagedata src="file:///C:\DOCUME~1\JESSER~1\LOCALS~1\Temp\msohtml1\01\clip_image001.gif" o:href="https://www.thirdgen.org/forums/images/smilies/eek.gif"/> </v:shape><![endif]--><!--[if !vml]--><!--[endif]--><o =""></o>
I have replied to the PM that I needed to and the forum has be cut of the things that are sold. PM me for anything you need.
And for your entertainment Pictures of the new little rocket <!--[if gte vml 1]><v:shape id="_x0000_i1026" type="#_x0000_t75" alt="" style='width:12pt;height:12pt'> <v:imagedata src="file:///C:\DOCUME~1\JESSER~1\LOCALS~1\Temp\msohtml1\01\clip_image001.gif" o:href="https://www.thirdgen.org/forums/images/smilies/eek.gif"/> </v:shape><![endif]--><!--[if !vml]-->
check my interior fourm and exterior for the exterior pictures
<!--[endif]-->
Old Sep 18, 2006 | 03:23 AM
TTT good deals here
InfinityShade
Aug 22, 2015 08:00 PM
Street Lethal
Aug 12, 2015 11:33 AM
sonu1975
Aug 11, 2015 08:38 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
