I got stuff that gots to go
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
factory drive shaft with new universals----------------25 bucks
factory shifter and cable----2 bucks
speedo cable--------2 bucks
water pump-------15 bucks
coolant and washer fluid reservoir------5 bucks each
2 mini turbo mufflers used in true dual set-up------10 bucks each
factory 305 "G" H.O. exhaust cross over----50 bucks
factory exhaust manifolds ported matched to heads-------15 bucks each
factory brake,fuel,vapor lines in mint shape------10 bucks each
comp cams valve springs shims and keepers new never used-------60 bucks
comp cams cam shafts new in box 3 cams for roller and flat tappet---------25 for flat tappet 75 for roller
double roller timing set-----10 bucks
valve covers-----5 bucks each
all factory accessory brackets for engine--------10 bucks each
alternator -------20 bucks
power steering pump------20 bucks
flex plates -------10 bucks each
starter-----20 bucks
factory water neck----5 bucks
factory rear disc brakes new calipers in box
all backing plates are sand blasted and in mint shape---------------250 negotiable for all rear brake stuff
front calipers--------------35 bucks for set
front spindles and backing plates glass beaded ---------------50 bucks for set
harmonic balancer-----10 bucks
factory pulleys------20 bucks for set
rebuilt 3 core radiator-------50 bucks
shipping is extra..... I will meet someone within reason in the cleveland ohio area
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Interested in:
Valve Springs
DoubleRoller Timing Set
Could i get pics and specs to:
i_break_stuff@hotmail.com
Thanks,
Sheldon
Valve Springs
Thanks,
Sheldon
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
What do you want for the Eibach pro kit springs? and what state are you in so I can guess on shipping.
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I'll take the cat. Pm sent
edit, just saw that i can't pm you. Please contact me at huffmanc1@central.edu
Engine: shinny 350
eibach springs are 150.00 plus shipping to anyone. I live in cleveland so I can meet you by sandusky
rear disc brakes with all hardware and brand new never used calipers are 250.00. I can be flexible
backing plates are factory
Last edited by jjlabinski; Jan 19, 2007 at 02:50 PM. Reason: Automerged Doublepost
Engine: shinny 350
I am willing to ship anywhere, but that would be extremely expensive due to size and weight.
carb is 100.00
water pump is 20.00
mufflers 15.00 each
springs 150.00
I have the kit whith several jets, springs, metering rods for the carb to so it can be dialed in to your application.30.00
fuel tank pick up with sending unit is 25.00 ----------------------- plus shipping
carb is 100.00
water pump is 20.00
mufflers 15.00 each
springs 150.00
Last edited by jjlabinski; Jan 19, 2007 at 04:11 PM. Reason: Automerged Doublepost
Engine: shinny 350
anyone interested please e-mail me at jjlabinski@***.net
thanks
attached is a photo of the car these parts came off of if it helps anyone
http://i56.photobucket.com/albums/g1...ski/car015.jpg
thanks
Engine: shinny 350
intake is edelbrock 2104
alt is v-belt all parts I am selling either have 10 hrs running time if engine related or new never used.
alt 20.00 plus shipping
Last edited by jjlabinski; Jan 19, 2007 at 04:17 PM. Reason: Automerged Doublepost
Engine: shinny 350
valve springs are un used. part# cca950-16 I have retainers, locks, shims and valve seals. 80.00 plus shipping for the above. all are new parts.
timing set is double roller. I dont think I used them either, I will check for wear pattern next trip out to the shop. One thing timing set will need is a brass indexing bushing. I used it on my current build. I think it costs 5.00 bucks or less.
Engine: shinny 350
rear disc brakes include: 2 never used calipers fully loaded.
2 rotors
glass beaded backing plates
parking brake cables
counter weights
I was looking to get 250.00
but will accept offers
2 rotors
counter weights
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
I am interested in the air cleaner, please PM with price
Also the Edelbrock carb!
-OSS
-OSS
Engine: shinny 350
sorry...250.00 is the lower so I will take that.
they are from my 84 T\A
that does not include shipping
Engine: shinny 350
the stuff
I put prices in the original post and lowered some prices on items to offset shipping costs.
thx
jeff
thx
jeff
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
AHH I see. Sorry man I was thinking they were the newer pbr barakes. I have a new powdercoated set of the same thing I cant give away. thanks anyway tho.
Car: 91 Z28 CONV
Engine: 468 BBC/500+HP
Transmission: TURBO 400
Axle/Gears: 9"FORD W/373 POSI
im interested in the gas tank sending unit for a carb car how much shipping to 11801 thanks john email me at fajdad@aol.com
pics of carb and intake to dillonrager@hotmail.com
thanks
thanks
Engine: shinny 350
chilli....cam specs comp cams 12-423-8 .502/.510 110 lobe separation 106 centerline
224/230@.050
I still have the intake as well
jeff
224/230@.050
jeff
Engine: shinny 350
here are the pics for those whom asked
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
