Complete 350TPI, 700R4 and Aluminum Driveshaft
Car: 1992 Camaro
Engine: 350 miniram
I just helped my buddy swap in his whole new drive train into his 1991 GTA, so now we have the whole stock drive train for sale.
What you get
Entire motor and everything attached including exhaust manifolds, y pipe, cat, and I have a whole catback setup as well to include, plugs, wires, distributor, speed density TPI including wire harness, full serpentine setup, still attached to the power steering pump is the quick ratio steering box which is included as well, radiator, and most importantly for V6 or carb people I also have the hard fuel lines to make instalation a snap. This should be everything needed to swap into your car without having to buy the little stuff to complete the swap.
Complete 700R4 assembly with cooler lines running up to the radiator
Aluminum driveshaft
This was a fully running assembly when we took this out of the car and before we took it out we made a sound clip of the motor running which I can send to interested parties. The whole setup is all attached and ready to be loaded up and taken away. I have done many swaps over the years and I have never got all the stuff needed without having to buy something. This should save you a ton of headaches of having to hunt down all the little things needed to get it going.
Because of the size this is going to have to be picked up in Central NJ, no shipping on this assembly unless everything is paid up front and you arange a carrier to come out and get it for you.
$1000 takes it all
What you get
Aluminum driveshaft
$1000 takes it all
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Complete 350TPI, 700R4 and Aluminum Driveshaft
More pictures available and a video clip of engine for sound too email me notchbackgta@hotmail.com
Car: 1986 Trans Am
Axle/Gears: 3.23 gears
I'm interesed...
please send me your contact info...
can you ship to Tucson? 85716?
I can help arrainge shipping, if that helps...
We'll need it crated and loaded... can you do this?
A truck can be sent to pick up, not sure about loading...
Thanks!
Andrew
Tucson, AZ
Thanks!
Andrew
Tucson, AZ
Car: 1992 Camaro
Engine: 350 miniram
Find a carrier that you would like to use and ask them how they want the drivetrain setup...ie pallet, crate, etc. I can have the drivetrain sitting on the driveway for them to pick it up but I'm not sure how they would want it packaged. I also have a large cherry picker that can lift it into the truck if they don't have that available on the truck.
Car: 1992 Camaro
Engine: 350 miniram
Make sure you sent the email to shara100@optonline.net
I haven't seen your email yet so try resending if possible.
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Would you be willing to sell the quick ratio steering box by itself? if so how much to 39654? up close pics please? to evb7@msstate.edu
Car: 1992 Camaro
Engine: 350 miniram
I have a couple of those boxes so I can sell you one of them. I'll take pics and send them to you this weekend and I'll include all the details.
Car: 1988 Camaro
Engine: 2.8L, soon to be 350/300HP
very interested, please send clip to basmtnrd@comcast.net , also how many miles are on this setup, where are you located in nj, if you would rather call my number is 484 3369329, or you can email me your number, Thanks Brandon
Car: 92 Firebird
Engine: 4.8 LR4
Due to response attached is the .mov clip so you can hear the engine in a zip format
Car: 1992 Camaro
Engine: 350 miniram
$1000 plus shipping and you will also get a 350TPI and 700R4
Sorry we don't want to break this up at this point.
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
I'm interested. I'm in central NJ hit me if you wanna sell,
kojo300zx@yahoo.com
kojo300zx@yahoo.com
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Is it still available? How many miles does it have?
Thanks,
-Tim-
Thanks,
-Tim-
Terrell351
06-13-2021 01:13 PM
