borg warner t5
Car: 1984 Camaro Z28
Engine: 2000 LS1
Axle/Gears: Moser 12 bolt w/4.11's
borg warner t5
Came out of an 84 camaro, i went thru it and replaced one shift fork, the clutch fork ball and cleaned everything. Transmission comes with bellhousing, clutch fork, Slave bracket, dust cover, thrust bearing, the used clutch pack, all of the proper hardware, and the stock flywheel i recently resurfaced w/proper shim. Bellhousing has a small hole in it, but that does not affect it at all.
Price: $550 plus shipping
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Re: borg warner t5
Does it come with the shifter?
How about $450.00 and I pick it up?
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
