TPI blowout!
Old 08-31-2008, 07:32 PM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
TPI blowout!
after spending millions to put together a functioning TPI system.... i ripped it out for a carb.
soooo everything must go
id like to sell it all together for ~500, trust me it cost wayyyyyyyyyy more to put it all together
TPI intake manifold, plenum, runners, injectors, throttle body, gutted air box, MAF,
wiring, computer, distributor and coil....... everything
all sensors included, ill give u everything i have
little history.
system came from an 89 GTA 350, some of the harness was modified to work with a camaro, the injectors are correct 305 ones, EGR and 9th injector delete, chip to delete these. most of the sensors have been replaced over the past 2 years.... im sure theres more......
Old 09-02-2008, 06:40 AM
maroman88's Avatar
Re: TPI blowout!
WILL SEPERATE!!!! let me know what you need!!
shes got a sweet BBK blue ajustable fuel pressure reg
Old 09-02-2008, 03:44 PM
maroman88's Avatar
Re: TPI blowout!
bumpppp for the evening
Old 09-02-2008, 04:19 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: TPI blowout!
I have a fuel press breed off problem and have been told it might be the AFPR so how much u looking for yours? have any pics tholtz10@aol.com thanks
Old 09-02-2008, 06:25 PM
maroman88's Avatar
Re: TPI blowout!
theres a pic installed, it has no more the 1k miles on it. i paid 60+ shipping, you can have it for 40 shipped... thanks
Old 09-03-2008, 07:12 PM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
Transmission: 700r4 auto
Re: TPI blowout!
this should bolt right up to my 88 camaro correct? im switching it over to tpi from tbi if so very interested
Old 09-03-2008, 07:26 PM
maroman88's Avatar
Re: TPI blowout!
yea it came off my 88, i still have it all, been getting pm's like crazy so let me know!
Old 09-03-2008, 07:57 PM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
Re: TPI blowout!
not to low ball you i just had to spend some unwanted cash all i got is 300 to play with
Old 09-04-2008, 12:43 PM
maroman88's Avatar
Re: TPI blowout!
all PM's answered
Old 09-04-2008, 08:43 PM
maroman88's Avatar
Re: TPI blowout!
wiring harness sold!
Old 09-06-2008, 10:16 AM
maroman88's Avatar
Re: TPI blowout!
ttt
Old 09-06-2008, 03:40 PM
maroman88's Avatar
Re: TPI blowout!
-AFPR...BBK, blue, 45 shipped
-TPI runners, 50 shipped
-TPI upper Plenum, $30 shipped
-TPI aluminum plenum extension distributor cover, 20 shipped
-TPI lower intake manifold, 65 shipped (its heavy)
-TPI fuel rail, 30 shipped
-TPI fuel injectors, 8, stock for 305tpi, 50 shipped
-TPI 9th injector set up, 20 shipped
-TPI stock throttle body, polished top plate, includes TPS and IAC sensor, coolant inlet and outlet passeges cut off, 45 shipped
-TPI remanufactured ECU with stock PROM for 88 305 tpi auto, # 1227165, 100 shipped
-Small cap distributor, recent cap, rotor, and ignition module, 100 shipped
-TPI air box, complete, gutted bottom of the box, 60.... odd size to ship so id rather it be picked up
-TPI MAF sensor, 50 shipped
-TPI camaro rubber intake boot, $20 shipped
-TPI Firebird/Trans Am rubber intake elbow, 30 shipped
-Rear view mirror with map lights, 25 shipped
-Rear view mirror with map lights, slight marks on glass, 20 shipped
-85-90 Rear Iroc bumper cover, perfect physical shape, will need paint to match your car, currently white, 50 pick up only
Old 09-07-2008, 03:22 PM
shibbykins's Avatar
Car: 91 RS Vert.
Engine: 350 TBI cammd
Re: TPI blowout!
i know you sold off some stuff what all is needed to bolt it upto my 350 in my 91 and how much shipped to 79924
Old 09-07-2008, 04:38 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: TPI blowout!
how much do you want for the serpentine belt set up i need all the brackets and pulleys to the ac,pwr steering and the alternator. i live in ny my zip is 11010
Old 09-07-2008, 06:11 PM
maroman88's Avatar
Re: TPI blowout!
thats not a TPI specific item... and wasnt removed for a carb swap
Old 09-07-2008, 06:17 PM
maroman88's Avatar
Re: TPI blowout!
only thing thats been paid for and i physicaly dont have any longer is the harness...
everything will bolt up to your 91 350 motor, but ull need larger injectors and a matching prom for the ECM. i can ship everyhting i have, minus the harness obviously, for 500
Old 09-09-2008, 04:54 PM
maroman88's Avatar
Re: TPI blowout!
ttt
Old 09-12-2008, 01:36 AM
maroman88's Avatar
Re: TPI blowout!
-***SOLD***-AFPR...BBK, blue, 45 shipped
-***SOLD***-TPI aluminum plenum extension distributor cover, 20 shipped
-***SOLD***-TPI MAF sensor, 50 shipped
-***SOLD***-85-90 Rear Iroc bumper cover, perfect physical shape, will need paint to match your car, currently white, 50 pick up only
Old 09-14-2008, 01:25 AM
maroman88's Avatar
Re: TPI blowout!
tttt
Old 09-16-2008, 07:16 PM
maroman88's Avatar
Re: TPI blowout!
bump
Old 09-17-2008, 03:52 AM
Want a title? Post!
mikeV's Avatar
Re: TPI blowout!
I'll take the upper plenum $30 shipped
Old 09-20-2008, 03:31 PM
maroman88's Avatar
Re: TPI blowout!
-***SOLD***-TPI runners, 50 shipped
-***SOLD***-TPI upper Plenum, $30 shipped
added 9/20
-headlight harness, correct for a 90 RS should fit 90-92 camaros without fog lights, $35 shipped
-TPI dual fan harness with relay, $25 shipped
Old 09-20-2008, 05:21 PM
swg74's Avatar
Re: TPI blowout!
I'll take the TPI stock throttle body and TPI fan.. email swg74@***.net
Old 09-21-2008, 12:32 AM
maroman88's Avatar
Re: TPI blowout!
email sent
Old 09-26-2008, 12:16 PM
maroman88's Avatar
Re: TPI blowout!
bumpppp
i also cut up a wiring harness from a 1990 RS camaro TBI and have pigtails with conectors to almost all the sensors, lemme know wat u need and i can shoot u a price
also have a set of 95Z28 stock "salad shooter" rims in great shape, would be ideal for a winter set. they have 2 good tires and 2 so-so tires, $150 picked up
Old 09-30-2008, 04:49 PM
maroman88's Avatar
Re: TPI blowout!
uppp
Old 10-03-2008, 06:17 PM
maroman88's Avatar
Re: TPI blowout!
uppp
Old 10-09-2008, 03:12 PM
maroman88's Avatar
Re: TPI blowout!
bumpppp
-***SOLD***Small cap distributor, recent cap, rotor, and ignition module, 100 shipped
added 9/20
-***SOLD***-headlight harness, correct for a 90 RS should fit 90-92 camaros without fog lights, $35 shipped
Old 10-18-2008, 12:26 PM
maroman88's Avatar
Re: TPI blowout!
bumpppp
Old 10-25-2008, 10:32 AM
maroman88's Avatar
Re: TPI blowout!
make offers! needs to goooo
Old 10-29-2008, 12:45 AM
therealmark's Avatar
Re: TPI blowout!
PM sent.
M.
Old 10-30-2008, 10:09 AM
maroman88's Avatar
Re: TPI blowout!
bumpppp
-***SOLD***TPI remanufactured ECU with stock PROM for 88 305 tpi auto, # 1227165, 100 shipped
added 9/20
Old 11-03-2008, 12:28 PM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Re: TPI blowout!
PM sent.
Old 11-05-2008, 12:05 PM
maroman88's Avatar
Re: TPI blowout!
please see updated thread!
https://www.thirdgen.org/forums/engi...tml?highlight=
stalkier
12-06-2015 11:25 PM
ChaseDale3and8
09-01-2015 01:49 PM
Keith5
08-27-2015 04:37 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: TPI blowout!
