Big COMP Hyd Roller Cam
Old Jan 20, 2009 | 01:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Cam is hydraulic roller with about one hour of run time. In great shape but I went bigger.
I still have the cam card...it is Comp's 3315/3316 on a 112 LSA.
.510/.520 lift
230/236 @ .050
If more info is needed please ask.
$200 obo
Old Jan 22, 2009 | 09:24 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Re: Big COMP Hyd Roller Cam
Bump
Old Jan 26, 2009 | 06:46 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Bump
Old Feb 7, 2009 | 10:22 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Bump
Old Feb 7, 2009 | 12:35 PM
Mike1234's Avatar
Gen1 / LT1 fit?
Standard firing order... or 4/7... or C-swap... or other firing order?
Pics?
Old Feb 7, 2009 | 03:10 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Both Gen I and LT1. For LT1 use you would need to pull out the shorter dowel pin and replace it with a longer LT1 pin, that's it.
The cam is perfect, the only thing you will notice is slight discoloration on a couple of the lobes seen in the last pic.
Old Feb 12, 2009 | 06:47 AM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
Might be interested, PM sent.
Old Feb 12, 2009 | 01:21 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
$150 shipped to Croatia is just not going to work. I'm sure the shipping will be $150.
Old Feb 12, 2009 | 03:27 PM
bvlahov's Avatar
Car: C4 Corvette
Engine: l-98
You're wrong, but nevermind. Good luck with sale!
Old Feb 14, 2009 | 10:32 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
still have the cam?
any cam # from comp so I can look up the info on it?
Old Feb 14, 2009 | 10:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Don't know if he has it or not, but I can attest to the fact that the numbers he has provided are Comp's Extreme Energy lobe profiles (3315 being the int lobe, 3316 being the exh) ground on a custom blank. Cam is designed for custom EFI friendliness.
Old Feb 16, 2009 | 10:33 AM
rossholio's Avatar
interested. Will it work on a retrofit block?
Old Feb 16, 2009 | 12:38 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Actually its not big, its only a bit bigger then ZZ4 which goes for 150$ including shipping to Europe.
Old Feb 16, 2009 | 01:55 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Bored Morit? Thanks for the bump.
This might work in a retrofit block but I am not sure. It is designed for factory hyd roller aps with the cam plate but I do not see why it would not work in a retro application with the correct cam button.
Old May 26, 2009 | 05:59 PM
91RedRagtop's Avatar
Car: 1991 Firebird Convertible Horsepow
Engine: 406 w/Motown 220 heads
Transmission: 5 speed manual
Did you sell the cam ???
Old May 26, 2009 | 06:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Yes. Sold.
junkcltr
Aug 2, 2019 11:12 PM
angel2794
Sep 8, 2015 06:22 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
