THE LIST OF EVERYTHING 3Rd GEN AND BEYOND
Old 11-04-2009, 01:58 PM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
EVERYTHING MUST GO, i am moving out and getting an apartment, and can not take any of theese parts with, or any parts at all for that matter, and i also have to sell my 87 iroc and 92 rs as well. i need a truck for the winter.
everything is located in wonder lake il, shipping is avail. shoot me a pm, repost, or txt at 815-307-2644(or call) if you are interested in anything. sorry some things are not third gen related but they are on my huge list and have to go. my name is keith and i look foward to hearing from you.
my 92 rs is either for sale the way it sits or will be parted out short of the carpet, radiator and rear axle. let me know if you want a RS project.
heres the list. thanks for your time.
Carburated Items
Edelbrock Perfromer 650cfm Manual choke Vaccuum secondaries 4bbl
4 bbl spacer plate
new in package throttle and tv cable braket for 4bbl
throttle cable bracket for 4 bbl
0-15 psi fuel press gauge for under hood
HEI distributor vaccuum advanced blue n black cap
new chrome wire looms
82-92 Camaro/Firebird/Transam Interchangeable parts
2 brand new in package 305 1987+ head gaskets
700R4 trans with T.c. under warranty
Drivers Door Skin only
158 tooth Flex plate
2 front plastic inner fender wells
hood latch and support
O.E. Center bolt V.C.
2 158 tooth starters
1 long nose water pump with v belt pulley
pair of small pin t tops
air pump
2 wiper motors
350 harmonic balancer
2 harmonic balancer v belt pulleys
1978 305 2 bolt main block only
TBI air cleaner, 1 top, 1 bottom, 2 plastic tubes
passenger side mirror Manual adjust
Grey rear over shoulder seat belts, both sides with 2 grey covers to convert
2 t top sunvisors 1 with mirror needs recovering
2 rear spring insulators
pair of side marker light housings
2 gold seat belt guides, go on headrests, and 1 black
2 e brake handles
fuse box panel cover
4 front bumper support spacers
set of 7 mm black plug wires
steering shafts, goes from collum to box
2 masters with boosters both good
1 rear disc perportioning valve
1 rear drum perportioning valve
GREY INTERIOR-pretty much every piece, even extras and black pieces too, buyer takes all
82-92 Camaro Specific parts
2 front noses both from an 86 sport coupe, 1 is pretty much Mint
1 sport coupe bumper support
3 sport coupe 15x7 wheels with junk tires 5 spoke steelies off of an 86 sport coupe
rear bumper off an 87 iroc good shape
2 rear RS springs
2 right fenders
1 repop left fender
1 Right tail light non grid
iroc chin with 2 repairable cracks
1 black seat cloth passengers, a lil faded, 1 small tear
fuse box
1 "CAMARO" side emblem goes on fender
sport coupe front licence plate bracket
82-89 dash support brackets steel refinished aka fr. speaker mounts
2 "camaro" center caps from an 86 sport coupe, for steelies
82-89 gauge bezel and clear face cover
82-89 panel for under steering collumm
82-89 dash sides for cig plug, defroster, headlight switch
1 small bottom vent and 1 tall top vent for 82-89 dash, both good shape
ECM from an 86 2.8 V6 Auto bought new havent used
82-92 Firebird / Trans Am specific Parts
front nose support from a 91 bird
2 front nose covers from a 91 bird both with cracks
2 front licence plate brackets from a 91 bird
2 front Fenders 1 L 1 R both in pretty good shape no rot, matching pair
2 front speaker grids great shape
dash pad, minimal cracks and damage
dash pad cover MINT
Map pocket, trans am logo, black leather, great shape
RH window motor out of a 91 bird
car stereo
kenwood kdc-4015 head unit
kenwood kac-628 amp 2 ch.
jvc kd-s580
vr3 200w 2 ch amp
head unit from a 91 firebird am fm cassette
head unit from a 86 camaro am fm cassette
first gen intrepid parts
digital heater control box
set of 4 ES alum. wheels
set of 4 5 spoke steelies
infinity amp
message center
non autostick gauge cluster with bezel
MISC.
1ST GEN CAMARO BLACK LEATHER SEAT GREAT SHAPE!!
Chrome Water pump pulley for Short Water pump V belt
1 black chrome exaust tip up to 2 1/2"
ford explorer Spare tire with new tire 15
olds cutless steel wheel 5 spoke 15x7
chevy cavilier wing
cold air filter with bent aluminum tube
Mongoose 24" mountain bike full suspension
20" chrome dyno frame and forks
20" frame make unknown
toshiba SD-R2312 CDRW DVD ROM
black leather poolstick case
surround sound speakers 5.1 non powered sub
Heilmans special import beer light small
auto gauge 8000 rpm tach all black 4"
auto meter electric water temp gauge black 2 1/8"
auto meter mechanical oil temp 100-340 W sensor
Tripple gauge pod new in box all black
4 chrome gas powered RC car wheels with tires with glow plug starter
2 universal mech grille inserts uncut sheets of apx 4' x 1.5'
2 manual fans chrome and blue for SBC bolts to water pump
2 camera tripods
Standard LX-316 module NEW in box
2 JBL 18" concert Speakers
Honda CR80 motor trans frame forks and other parts
magnaflow stainless cat back for tuners
Austin Au-20b 20W Bass Amp
misc. box of computer memory chips, coolers, fans and cords
Old 11-04-2009, 03:41 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
Re: THE LIST OF EVERYTHING 3Rd GEN AND BEYOND
how much for the auto meter mechanical oil temp 100-340 W sensor and the auto meter electric water temp gauge black 2 1/8" sent to 46561? and can i get pics? thanks Ty.
Old 11-04-2009, 04:21 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
(1 rear disc perportioning valve)Price with shipping to 25701. Thanks Oh yea what year is it off of.
Last edited by wvabreeze; 11-04-2009 at 04:23 PM. Reason: forgot to ask a question
Old 11-04-2009, 05:11 PM
89irocz28350's Avatar
Car: 89 Iroc Z-28
Engine: 5.7 350 TPI.
Axle/Gears: Borg Warner 9bolt 2.77
does the 87 have a 9 bolt Borg Warner rear end? If so what ratio?
Old 11-04-2009, 07:39 PM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
how much for the vette wheels off the rs
Old 11-05-2009, 04:48 PM
pms sent
Old 11-10-2009, 05:34 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
do you still have the guages?
Old 11-26-2009, 03:18 PM
gauges still avail
bump
Old 11-27-2009, 07:56 AM
DontBlnkBadWolf's Avatar
Car: 2002 Dodge Ram 1500 Quad Cab
Engine: 4.7 Liter
Transmission: 4 Speed Auto
PM sent to you @ 8:55 am E.S.T. on 11/27/09
Old 11-27-2009, 10:47 AM
petko0's Avatar
Engine: built 350 TPI
what can you tell me about the 700r4 that you have?
Old 11-28-2009, 05:55 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
DUDE, GET A STORAGE BIN AND KEEP THIS STUFF!!!!
Old 11-30-2009, 10:42 PM
no way i can keep it all, hell no, my next car after i get rid of my 92 rs and my 87 iroc will be an 03 300c, so i dontreally need any of it. lol
trans is sold
Old 12-07-2009, 12:30 AM
redtruck18's Avatar
Car: 1987 RS Camaro
Engine: 305 V8 (Carb)
Great deal on a transmission, cant wait to get it and install it.
thanks,
Joe
Old 12-07-2009, 10:02 AM
bump
Old 12-07-2009, 10:44 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Price on the 86 Sport coupe nose that is real nice. Does it have all the lower valance pieces for cooling?
Stuckin2nd@gmail.com
Old 12-12-2009, 06:10 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
how much for the cr 80 engine and trans shipped to 32246?
Old 12-12-2009, 10:48 PM
pms sent
Old 12-27-2009, 03:12 PM
91aress's Avatar
did you decide if parting out the 92 rs? is it 305 tbi? if so how much for co9mputer?
Old 12-27-2009, 08:30 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
How much for the centerbolt valve covers shipped to 62326? And do they come with the bolts and grommets?
Old 12-27-2009, 11:25 PM
pms sent
Old 07-08-2010, 12:21 PM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
hey i need a Throttle cable,Kickdown cable,fuel lines and fuel pump and brackit on side of tpi how much for them and how much fro shiping to V0N 2P0 ?
Old 07-08-2010, 01:58 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
4 bbl spacer plate
How much shipped to 22602?
Old 07-13-2010, 04:44 PM
89Firebin's Avatar
Car: 89 Firebird Formula 350
Engine: 1974 350
Transmission: '84 Trans Am T5
Axle/Gears: Borg warner 3.27
Are any of the starters T5 Starters?
Thanks.
Old 07-13-2010, 04:58 PM
Want a title? Post!
twoofakind's Avatar
Car: 1985 Z28 X2
Engine: 350 290HP crate
Transmission: T5 WC / 700R4
Axle/Gears: 4.10
Is the throttle/tv cable for the edelbrock? How much shipped to 30144?
Old 07-14-2010, 04:59 PM
OGG_666 ------ ill have to goto my parents house to see if i have any of that stuff still
JTNKTZ ----- i am pretty sure i have all those still but let me put my hands on them first and ill p m you as soon as i do that
87FireBin ---- no they are not sorry
twoofakind ----- no it is not sorry
i havent been on for awhile and i do not live with my parents anymore and all my stuff is there... i can go there every now and then to get stuff and ill see what all i have still.... thank you for you guyss patience
1992rs/ss
05-19-2020 07:02 PM
deracer
04-11-2016 12:04 AM
Warlocksirix
09-03-2015 12:26 PM
Bstrang6
Brakes
08-24-2015 06:45 AM
tricky1
08-23-2015 01:17 PM
Quick Reply: THE LIST OF EVERYTHING 3Rd GEN AND BEYOND
