[FL] Misc. Engine accessories
Old Aug 29, 2010 | 10:20 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I have some left-over parts I no longer need:
-Mallory 4309 Adjustable FPR, paid $100 from local speed shop, hardly used, and comes with brass fittings - $70+shipping
http://www.summitracing.com/parts/MAA-4309/
-Mr. Gasket FPR, hardly used - $10+shipping
http://www.summitracing.com/parts/MRG-9710/
-Aluminum rail-style spark plug wire seperators - $20+shipping
Same as these: http://www.summitracing.com/parts/SUM-440320/
-Complete set of Serpentine belt accessories: Both brackets, New alternator, New AC/Delete pulley, Waterpump, Power steering pump, etc.. - $150+shipping
-Stock 2-core V8 radiator - $30
-3-core v8 Aluminum fin/Brass sided radiator - $50
-Hayden Stacked-plate style Automatic transmission fluid cooler, cost $55 from summit, never driven with - $25+shipping
-New(er) starter, worked with my 1pc RMS SBC, and T5 tranny - $40+shipping
-New T5 clutch hydraulics with line and resevoir, cost $100 for Slave and master, low miles - $50+shipping
Need any pics? Please ask!
Thanks.
Old Aug 30, 2010 | 01:20 AM
Re: Misc. Engine accessories
up
Old Aug 30, 2010 | 02:36 PM
up
Old Aug 30, 2010 | 08:01 PM
up
Old Aug 30, 2010 | 09:54 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Price for 3core radiator shipped to 62959?
Old Aug 30, 2010 | 10:02 PM
Shouldnt be any more than $70 shipped.
Old Aug 31, 2010 | 12:20 PM
up
Old Aug 31, 2010 | 09:08 PM
up
Old Oct 11, 2010 | 11:37 PM
Kolby's Avatar
Car: 1988 Trans Am GTA
Engine: 350 5.7
Photos of alternator?
Old Oct 18, 2010 | 07:35 PM
Mallory fpr, and wire seperators sold.
Old Oct 19, 2010 | 05:37 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Where in florida are you? If your not too far from me, I will want the clutch hydraulics and resevoir.
Old Oct 19, 2010 | 11:08 AM
I'm far, lol.
Tampa.
Old Oct 19, 2010 | 02:05 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Originally Posted by bradley23150
I'm far, lol.
Tampa.
If you don't mind could you check the shipping cost for the clutch hydraulics and reservoir to 33196.
Old Oct 19, 2010 | 06:55 PM
Shouldnt be more than $5-7 tops.
Old Oct 19, 2010 | 07:12 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
pics for clutch hydraulics and reservoir plz...
Old Oct 21, 2010 | 06:59 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
could you tell me a bit more on the serpentine set-up? Is it powdercoated yet, or just a powerwashed original set. Are all the 'extra's new, newer, or? And are ya set up with Paypal? I could put the trigger now, but I'm not looking to rebuild everything. Thanks, and I look forward to hearing back from you! Sincerely, Nitro-Nicky
Old Oct 21, 2010 | 02:25 PM
The brackets, crank pulley, power steering pump, and waterpump pulley are what were on the engine when I got it. I replaced the waterpump, alternator, delete pulley, and belt because I wanted new parts that I could trust on my car. The brackets and everything arent powdercoated, I didnt even really clean them off, I just removed them because I went with an LT1 engine, and those parts wont work on it. One thing I noticed is that the idler pulley squeaks when the engine is running, and gets annoying, so it may need a new bearing or something.
Old Oct 22, 2010 | 06:51 PM
neagan's Avatar
Thanks for responding. That's pretty much where I'm at in the final paint/powdercoat/assembly process; so I thought I'd check before I got mine sent in and bought new power steering parts and nicer brackets. Good Luck though!
Old Oct 22, 2010 | 10:38 PM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
willing to part with the resevior and the line that goes from it to the cyliner?
Old Oct 23, 2010 | 02:21 PM
Trying to keep it as a set. I actually can't find that line, though...
Old Oct 27, 2010 | 08:42 AM
partsbin321's Avatar
Car: 1987 Iroc
Engine: 502
Axle/Gears: Ford 9" 3.73
You have a private message about the radiator.
Old Oct 27, 2010 | 06:30 PM
pajama sam's Avatar
shipping to 60056 on the 3 core radiator. thanks
pm me
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
