[MO] Adj. TPI regulator, 24PH injectors, throttle body
Car: 2001 GMC Jimmy
Transmission: Nv3500 5 speed
Axle/Gears: Dana 44's f&r, 4.30 gears
Have an adj. fuel pressure regulator off my TPI set up. Dont know what brand. Works fine. went to an aftermarket reg. Hows 35 shipped.
Also have a set of 24 pound injectors from my motor. Work fine. Running a 305 in my project now so dont need these. Hows 50 shipped.
Also have a stock TPI throttle body. has Iac and TPS sensor. Needs the Iac and top plate gaskets. Make offer.
All prices are OBO. Dont need any off these anymore.
Car: 2001 GMC Jimmy
Re: Adj. TPI regulator, 24PH injectors, throttle body
Will ohm them later and post up. I bought them from a member here. They came from and LT1
Car: 2001 GMC Jimmy
& of them ohm at 12.4. the other one at 12.5.
Car: 2001 GMC Jimmy
I had them in my TPI setup. Ill Pm you my paypal addy.
Car: 2001 GMC Jimmy
Sold them already to swich2112.
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
I am interested in the throttle body if you take of the top plate and the IAC housing. I do not need the TPS sensor either, so you can remove that as well.
What would be the price of it shipped to 33166?
Car: 2001 GMC Jimmy
Hows 25 shipped sound. I have that one and other one that aint painted. Both are the same.
