[MO] 24 lb injectors Barely used 200 or trade for nitrous accessories
Car: 1986 Iroc-z Camaro t-top
Engine: 355 SBC
Transmission: 700r4 TCI const. Pres. Valve body
Axle/Gears: 3.73 posi/mosuer axles
200 OBO
Engine: 355 SBC
Re: 24 lb injectors Barely used
Bump/ trade for nitrous parts/accessories
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
What brand are these?? may be interested if they're not Accel
Engine: 355 SBC
Re: 24 lb injectors Barely used 200 or trade for nitrous accessories
They are performance injectors. That is the brand
200 shipped??
Actually.... I just re-did the math on my injector requirements and 24 lb/hr isn't quite enough for my build so I'm going to have to pass.
Good looking injectors and a good price though!
Free bump!
Free bump!
Engine: 355 SBC
200 shipped..I had these on 355 tpi with aluminum heads and cam worked good I'm sure you don't need bigger.. What is your combo
According to my math a 26lb injector is what I'm looking for. But of course, that is all in theory.
Engine: 355 SBC
Do you have an adjustable fuel pressure regulator? I would think you'd be alright with 24s I had same heads just brodix and a .480 lift crane cam with about 9.8.1 compression. My motor was running way to rich I never got a tune before I decided to carburet it. If you don't have an afpr I can throw mine in.. It's t.p.I.s was about 90 dollars by the time it got here, but I know when it comes to buying performance parts it's better to get more than what you need. I'm sure you'll be doing some more upgrading in the future that would require more than 26s. I believe ls1s come stock with 26 or 28 So if I was in your position id prolly do atleast 26
Yeah, i've got a Holley AFPR so I'm good to go there. Yeah, 26 is what I came to figure out so I may just go in that direction anyway. I'm not even close to getting my motor in the car yet anyway I just saw your sale on these and thought I'd hit you up on them. I may still go with them as they will also look good on my motor as they match my color combo and I'm sure I could probably get away with 24's but you're right that 26 to 30 would probably give me more breathing room for future upgrades.
Engine: 355 SBC
yep just lmk im sure ill still have them
ambainb
Apr 25, 2016 09:21 PM
92projectcamaro
Jan 18, 2016 08:00 AM
