[MD] third gen air/fuel, sway bar, serp setup
Car: 86 sport coupe, 89 IROC-Z
Engine: 5.7 TPI, 5.0 TPI
Transmission: T-5, T-5
Axle/Gears: drum posi 3.73, disc open 2.73
TPI system with either canted bolt (86 and up SBC) intake or standard intake (85 and back SBC). Everything without harness or PCM. Plus 1 set of new gaskets. Also a spare set of runners, MAF for a 5.0 and an EST module.
$150 you ship or pickup
TBI intake and TB both rough but usable for parts
FREE pickup only
88 GTA 5.7 serpentine setup. Brackets bolts and pulleys $40 you ship or pickup
88 GTA front sway bar
88 GTA aluminum mini spare
$10 you ship
service manuals for 90 firebird and 92 firebird
$20 each you ship
86 z28 cluster for parts with extra tach
$10 you ship
86 2.8 hypertech chip
$25 you ship
Jacobs spark computer with remote coil hei harness
$150 you ship
set of 8 Ford 4.6 Injectors
$25 you ship
21057 baltimore MD
FREE pickup only
$10 you ship
$20 each you ship
$10 you ship
$25 you ship
$150 you ship
$25 you ship
21057 baltimore MD
Re: third gen air/fuel, sway bar, serp setup
No problem. I made some fuel lines too for tuned-port they go with it.
Bump for new parts added
You might want to consider picking up or meeting halfway. For just the brackets bolts and pulleys its $32.77 shipping. Ill ship it all for $80 or you can pickup for $40. None of the accesories as it turns out are useable.
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Interested in the AL spare to 66216
Also, is the lens for that cluster very faded? I'm assuming it's the same as in an 87 IROC?
Its the pro-street energy pak http://http://www.jacobselectronics.com.au/
retails for nearly $400 with the harness. Its plug and play and comes with instructions
I have two face plates, neither is faded. One has a scratch. It sould work but I would do some research if I was you. I think all the gauges work exept one tach, but the lightbulbs and some little screws are gone thats why Im selling it "for parts"
UPS would ship it much cheaper than that I'd think.
As far as the cluster I would only need the clear cover panel if it's the correct layout.
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
