[NY] Heavily ported aftermarket TPI setup
Old 05-15-2011, 11:34 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Edelbrock TPI base, siamesed and ported
SLP runners Welded, raised port, machined and matched to intake, siamesed top and bottom, still some meat to be taken out if you want to get more aggressive with the porting.
Plenum- runner openings enlarged and siamesed, throttle body opening enlarged, egr wall knocked down
58mm Throttle body, I think it's a BBK gotta look
Wish I knew what this setup would run but it was replaced with a single plane and turbo before I got that far. If you buy it you will keep the community informed on what kind of numbers this setup puts out
The intake and runners will absolutely not be separated, they are heavily modified and are a set, you'll see once pics are up, pic hosting service is down, should be there tomorrow. Gaskets for this will need to be hand cut, I'll throw in gasket material. $800 takes the whole setup
Will consider trades, I need Aftermarket subframe connectors, Lower Control Arm Relocation Brackets
Old 05-16-2011, 07:36 AM
Car: 91 Formula
Re: Heavily ported aftermarket TPI setup
Old 05-25-2011, 08:06 AM
Car: 91 Formula
Bump $700
Old 06-14-2011, 06:48 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Still got this?
Old 06-14-2011, 09:50 PM
Car: 91 Formula
Yes, still available.
Old 06-14-2011, 11:59 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
You got a pm
Old 08-01-2011, 09:23 PM
Car: 91 Formula
Bump! Need to save money for a donor car, frame is shot...
Old 10-28-2011, 09:49 PM
Car: 91 Formula
Bump, finished moving gotta make room in garage. Will go on ebay next week...
gta90
09-15-2015 04:00 PM
masonta
08-31-2015 10:14 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
squiggy2
08-09-2015 09:30 PM
Quick Reply: [NY] Heavily ported aftermarket TPI setup
