[MI] Bonspeed wheels from the IROC-Z for sale
Old Aug 25, 2011 | 05:02 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Hey guys,
I'm selling the wheels (Bonspeed Huntington) and tires off the IROC. The sizes are 18x8 front and 18x10 rear with Toyo Proxes T1R's. Tread is very good. The tires hold air (no leaks) and have never been plugged. Wheels are in very good condition also. These were custom made to fit the car which is standard for any 3rd gen...will not work on a 4th gen. Wheels and tires cost me $3K new. Looking to get $1700 for them right now. I think that's a very fair price for a higher end wheel. These are not cheap cast wheels the centers are machined from 6061 T-6 billet forgings. They are 2 piece wheels with the center welded into the hoop. The wheel/tire combo has about 12K miles. I bought them back in 06. Wheels have never been curbed and show very little signs of use. They usually get polished inside and out once a year. I have tons more pictures of the wheels, so if your serious about buying and want to see them, let me know. The wheels are located in Grand Rapids MI. Buyer to pay shipping.
Specs on the wheels:
Front 18x8 with a 4.75" backspace
Rear 18x10 with a 6.0" backspace
Tires: Toyo Proxes T1R's with around 12Kmiles
Front is 245/40/18 Tread depth is .250"
Rear is 295/35/18 Tread depth is .160"
Front tire/rim weighs 49lbs
Rear tire/rim weighs 56lbs
Detail of one stone chip..this could be sanded and polished out if someone was ambitious enough.
Front tire tread
Rear tire tread
Old Aug 25, 2011 | 07:44 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Re: Bonspeed wheels from the IROC-Z for sale
I know its along shot but trade for my Ronal wheels and a little $$$? Either way wheels look great.
Old Aug 25, 2011 | 08:39 AM
406TPI's Avatar
Car: 1985 IROC-Z
Sorry, no trades. New wheels already picked out....just waiting to sell these until I pull the trigger on having the new ones made.
Old Aug 25, 2011 | 08:46 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
If my Ronals sell i will def be picking these up. Cant wait to see the new wheels also.
Old Aug 25, 2011 | 09:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Any pics available of the rear wheels installed? I'm trying to see how far they stick out compared to stock. Any issues with the rear tires rubbing?
Old Aug 25, 2011 | 11:04 AM
406TPI's Avatar
Car: 1985 IROC-Z
Haha...you already asked me that years ago.....check it out...more pics of the wheels right after I got them. You said they would not work for you back then, I think they will, my car is low and they never rubbed the fender...the pic is a little deceiving. These wheels would look killer against a red car.
https://www.thirdgen.org/forums/auto...ed-wheels.html
Old Aug 25, 2011 | 12:55 PM
Jim85IROC's Avatar
At least I'm consistent. I'd forgotten that I asked back then.
If I get a chance tonight I'll pull the springs out of the rear of the car and compress the suspension until I'm on the bump stops to see what things look like with my factory setup. I seem to hit the bump stops a LOT on my car, so I need to make sure there's room.
Old Aug 26, 2011 | 04:56 AM
406TPI's Avatar
Car: 1985 IROC-Z
You should be fine. I'm on factory springs that are cut. I only had one minor rub issue on the inside of the wheel well on the passenger side at full compression...I believe it was the bump where the seat belt anchors are.
Old Aug 27, 2011 | 12:24 PM
83 Crossfire TA's Avatar
Are those aftermarket brakes? Do they space the wheels out any (that front backspacing sounds like it might put the front wheels in about 1/4" too far with the factory setup)?
How much is the car lowered in the pics?
Looks sweet!
Old Aug 27, 2011 | 02:09 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
How much caliper clearance do you have in the front? Any idea if a Baer monoblock 6 piston caliper would clear? I am very interested but I need to make sure they will clear my brakes.
Old Aug 27, 2011 | 06:38 PM
406TPI's Avatar
Car: 1985 IROC-Z
Looks sweet!
Those are LS1 brakes front and rear, so yes the front wheels backspace account for the extra thickness of the rotor hat....I think it's around a 1/4" or less. Car is lowered about 1.5"
They have pretty good clearance....I know the valve stem would have to be changed to a flush stem to fit bigger brakes. I was planning on running the CTSV set-up with these wheels, I measured for them and they look like they will fit....I don't know about the monoblock though. Would you like me to take any measurments?
Old Aug 27, 2011 | 07:03 PM
91 1LE's Avatar
Car: '91 1LE
This is the template that Baer supplies with my brake kit. It would be awesome if you could see if these will fit. I love the wheels and I hope they fit without spacers. Now I run an 18" C6 front wheel with a 2" spacer but I don't like the way it looks. Sticks out too far. The Baer kit also adds a 1/4" to the hat thickness so thats a good start. http://www.baer.com/brake-templates/N085P.PDF, http://www.baer.com/brake-templates/...structions.pdf. Thanks in advance for checking fitment.
Old Aug 27, 2011 | 07:26 PM
406TPI's Avatar
Car: 1985 IROC-Z
No problem, I'll check it out tomorrow.
Old Aug 28, 2011 | 04:39 PM
406TPI's Avatar
Car: 1985 IROC-Z
Here you go....it's tight. There is about .080" to the inside of the rim. To the spoke it's about .350". You can see the valve stem would have to be swapped out for a flush stem.
Old Aug 28, 2011 | 08:10 PM
91 1LE's Avatar
Car: '91 1LE
You checked the scale with a ruler? It's under the recommended 0.10" clearance but I think it will work. Shipping quote to 85340 residential address please. You can PM me if you prefer. Thanks
Old Aug 29, 2011 | 04:52 AM
406TPI's Avatar
Car: 1985 IROC-Z
Yep, it's printed exactly to scale. I put the blue tape on the end to make it easier to see the gap.
I'll work on a shipping quote.
Old Aug 30, 2011 | 07:24 AM
scholtmj's Avatar
Car: 88 Trans Am Hardtop
Engine: 350 L98
Transmission: Stock 700R4
Axle/Gears: 3.27 Aussie 9
Bump for a great seller. These wheels are cleaner than advertised, well cared for!
Old Aug 31, 2011 | 04:43 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
are they sold?
Old Aug 31, 2011 | 04:46 AM
406TPI's Avatar
Car: 1985 IROC-Z
Originally Posted by ted gerlach
are they sold?
Not sure...waiting to hear back from the guy above. I'll keep you posted.
Old Sep 3, 2011 | 05:48 PM
QUICK305's Avatar
Please place me in line if these are not sold.
Old Sep 5, 2011 | 10:38 AM
406TPI's Avatar
Car: 1985 IROC-Z
Will do.
Old Sep 7, 2011 | 06:03 AM
406TPI's Avatar
Car: 1985 IROC-Z
Sold!
Old Sep 7, 2011 | 07:45 AM
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Originally Posted by 406TPI
Sold!
Congrats!
Old Mar 7, 2012 | 05:10 AM
Transmission: auto
i bought them cant wait to get them on the car
colton_carlson
Mar 8, 2019 12:21 PM
g.l.mos
Aug 22, 2015 12:02 AM
overdriv
Aug 20, 2015 03:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
