Accel 1350 cfm Throttle Body
Old Dec 4, 2011 | 09:32 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Accel 1350 cfm model 74202S3 Throttle Body. I had this on my motor for maybe 25 miles. The unit is in brand new condition. It has TPS and IAC. Progressive linkage. Contact me for pics.
$285.00
Attached Thumbnails Accel 1350 cfm Throttle Body-dscn0312.jpg   Accel 1350 cfm Throttle Body-dscn0313.jpg   Accel 1350 cfm Throttle Body-dscn0310.jpg
Old Dec 4, 2011 | 01:54 PM
blackdoutgta5.7's Avatar
Car: 1989 gta
Engine: 5.7 ltr
Axle/Gears: 9 bolt 3.27 limited slip
Re: Accel 1350 cfm Throttle Body
so why are you selling it
Old Dec 4, 2011 | 03:44 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Decided to pull out the 406 and install a milder 383. I want to be able to let my son drive the car but it's way too much motor right now. I'll be selling the 406 short block in the next few months.
Old Dec 5, 2011 | 06:45 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Bump
Old Dec 7, 2011 | 09:17 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Accel 74202S3, Accel Billet 4150 Series Flange, Billet Throttle Body, 4150 Series Flange, 1350 Cfm, W/Idle Air Control And Throttle Positive Sensor,, Stainless Shaft For Excellent Corrosion Resistance, Blades Are Hand Lapped To Provide Min. Air Leakage, Provides Excellent Idle Control, CNC Machined To Precise Tolerance
Old Dec 9, 2011 | 05:16 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Bump
Old Dec 11, 2011 | 04:24 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Bump
Old Dec 28, 2011 | 08:59 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Bump
Old Jan 3, 2012 | 07:45 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
New pics added.
Old Mar 27, 2012 | 08:47 AM
tslsa28's Avatar
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
Do you know if the TPS and IAC will plug directly to the TPI wiring harness and computer?
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
