[IL] New "Ultimate" NOS Super Power Shot Nitrous, New Edelbrock 210 Heads, + Tons More
Old Mar 31, 2013 | 06:48 AM
SoCo80p's Avatar
Up for sale is an "ultimate" NOS super powershot nitrous kit. The package includes the NOS super powershot nitrous kit itself which is adjustable from 100-150 HP, an MSD digital 6 ignition box which has an adjustable rev limiter, start up ignition retard, and ignition retard when the NOS is activated, a jeg's digital window switch with LED display and tach, an NOS low fuel pressure shut off switch, NOS purge kit, jeg's billet carb mounted activation switch, and a NOS threaded safety blow off bottle valve.
This setup is decked out with all the bells and whistles to have the safest, most complete nitrous kit to have it installed right.
I will take $525 for the nitrous kit itself
$280 for the digital 6 plus box
$100 for the for the purge kit
$25 for the fuel pressure safety valve
$45 for the digital window switch
$25 for the billet carb mount activation switch
Or $950 for everything.
Edelbrock E series 210cc aluminum cylinder heads for small block chevy. The package includes everything you need from the heads, massive 2.08/1.60 stainless steel swirl polished valves, screw in rocker studs, viton valve seals, guide plates, springs, locks, keepers, spring seats,...etc. All is brand new in the box and ready to go! $1,100 takes everything.
New comp cams extreme energy 274 cam and lifter set (230/236 .490/.490) Will take only $175. Sells for $211.90 with shipping from Summit.
4 piece taylor wire set $10
Sears power drill $20
MSD hei to hei plug style coil wire $8
Chrome alternator bracket X2 $15
Chrome radiator hose neck $5
Dwell/points/tach meter $25
Hard to find reclining seat bar $65
Chrome distributor hold down $5
Chrome fuel pump block off plate $7
4 piece new in the package keystone offset washers for GM cars $7
70-81 firebird glove box door $20
re-pop battery tray with holddown $15
Chrome timing pointer with adjustable pointer for small block $5
New set of 4 axle u bolts with hardware, $25
New pair of Fel-pro 1004 head gaskets with the brodix mods to allow them to be used on 400's without having to drill steam holes in the heads, $70
2 new pairs of 7/8" sway bar bushings, $8 a pair
New set of 4 Moog upper control arm bushings, $30
Cragar street star wheels. Two are 14x7 and two are 14x6, GM 5x4 3/4" bolt pattern. Includes 4 brand new in the package center caps. $250 takes the set
Old Mar 31, 2013 | 07:07 AM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
Re: New "Ultimate" NOS Super Power Shot Nitrous, New Edelbrock 210 Heads, + Tons More
DO you have a part number for the "New set of 4 Moog upper control arm bushings''
Old Mar 31, 2013 | 07:16 AM
SoCo80p's Avatar
They fit 70-81 F-body.
Old Mar 31, 2013 | 07:21 AM
rawley2's Avatar
I thought something was up because our cars don't have an upper control arm.
Old Apr 5, 2013 | 01:50 PM
SoCo80p's Avatar
Bump
Old Apr 8, 2013 | 01:33 PM
SoCo80p's Avatar
up again
Old Apr 9, 2013 | 09:51 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Wish I had the money for that NOS and cam kit more so NOS
Old Apr 11, 2013 | 09:11 PM
SoCo80p's Avatar
Let me know if you get the funds!
Old Apr 11, 2013 | 09:46 PM
Joe Tag's Avatar
210 cc heads huh? What you mean to say is 64cc heads 210cc is the intake runner volume.
Old Apr 12, 2013 | 11:57 AM
SoCo80p's Avatar
Correct.
Old Apr 17, 2013 | 05:32 PM
SoCo80p's Avatar
Wheels pending sale
Old Apr 23, 2013 | 09:27 PM
SoCo80p's Avatar
Wheels are sold
Old Apr 24, 2013 | 12:46 AM
Sojer's Avatar
Are u out the 3rd gen game will u take trade for some of the nitrous stuff
Old Apr 24, 2013 | 07:09 PM
SoCo80p's Avatar
Just looking for cash, thanks.
Old May 4, 2013 | 05:03 AM
SoCo80p's Avatar
Back up
Old May 11, 2013 | 12:30 PM
SoCo80p's Avatar
bump
Old May 21, 2013 | 04:03 PM
SoCo80p's Avatar
back up
Old May 29, 2013 | 04:58 PM
SoCo80p's Avatar
MSD box, purge, and window switch are sold.
Old Jun 3, 2013 | 04:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What he meant to say is what he said. Anyone who knows anything about cylinder heads knows what 210cc's means. If not they have no business buying heads like this.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
fasteddi
Sep 2, 2015 10:29 AM
86IROC112
Aug 17, 2015 02:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
