[FL] *FREE*AIR Injection System components
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Some dastardly devil removed all of my SMOG related components, and I would rather see if anyone needs them before throwing them away. AIR pump turns smoothly, diverter valve/solenoid assembly complete, and two check valves with no rust. You pay shipping, its yours.
Car: 87 Iroc z
Axle/Gears: 3:27
Re: *FREE*AIR Injection System components
Do they work ok? If so find out shipping and I will take them. By that I mean will they still work to pass emmisions? We have to pass that out here in the desert, visual as well as sniffer.
Car: 1991 red Z/28
Transmission: T5 swap
Do you have the molded rubber hose that runs from the left check valve to behind the engine then up to the d valve?
Engine: 5.0
I cut the hoses. As far as I know, everything is functional. No guarantees, the motor only ran for 5 minutes in the past 14 years.
Engine: 5.0
I still have everything. Flat rate shpping boxes from USPS typically run 10-15, I just didn't want to waste the time going to the post office, getting prices, driving BACK to the post office to ship free items. Let me know what you need
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Do you have the metal air tube that goes from the pump to the cat?
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
Thanks and I understand that..I need the drivers side air injection pipe that goes into the manifold an the check valve on it..not sure these are parts you are talking about though.sure would appreciate it...Dan
Engine: 5.0
I do not have any pipes. And rich, great idea. I will post tomorrow when I get to work
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
