[TX] Lloyd Elliott ported AFR 1040 195cc heads
Old 06-29-2016, 11:00 PM
LT1Formula's Avatar
My dad has decided not to build his 89 GTA so these heads are now for sale. We bought them brand new from a member here on the forum and then had Lloyd port them. We never ran them and then sold them to another member who sold them back to us. That's the backstory on how we ended up having them again.
AFR 1040 195cc heads. 65cc Chambers, 2.05/1.60 valves, studs and guideplates included, believe they are 3/8 studs. An identical set of AFR 1040 heads we had ported by Lloyd flowed 310/230@.600 lift. We didn't have this specific set flowed but they are great heads ready to make some good power. Heads are $SOLD.
Old 06-30-2016, 09:08 AM
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Re: Lloyd Elliott ported AFR 1040 195cc heads
Pm sent
Old 06-30-2016, 11:12 AM
LT1Formula's Avatar
PM replied. Also I will get some closer pics of the porting. Lloyd is the man and he absolutely made these gorgeous.
Old 07-12-2016, 12:46 AM
LT1Formula's Avatar
Bump.
Old 07-25-2016, 01:09 AM
LT1Formula's Avatar
Bump.
Old 08-08-2016, 12:48 PM
LT1Formula's Avatar
Bump.
Old 08-08-2016, 09:58 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Pm sent. Only question is would these be overkill on a 350 with an LPE 219 cam?
Old 08-14-2016, 03:46 PM
LT1Formula's Avatar
Heads are SOLD.
Old 08-15-2016, 09:25 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
To answer your question even thought he item in question is sold.
Its both yes and no.
The 195cc port isn't too large for that size cam, so you'll still have good intake velocity on a 350 size engine.
I have a set of AFR 195cc heads on my LT1 and with my 350 they will make power past 7000rpm with the right cam.
You would gain a good chunk of power in the 5500rpm+ and the engine would not fall off quickly, but ultimately you would be leaving performance on the table. Especially with a TPI style intake which would restrict high end flow.
