[OR] EBL Flash-II with port mod (for TPI)
Old Dec 3, 2019 | 01:03 AM
GeneralDisorder's Avatar
I switched over to a LINK standalone so I have no need of my EBL. I bought it about a year ago, Served me well but it's time to move on for me. Comes with all cables and software. $400 shipped. Was a little under $500 new. PM me, etc.
GD
Old Dec 4, 2019 | 09:46 AM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: EBL Flash-II with port mod (for TPI)
Why the switch over to the LINK ECU? Those things are pricey. Seems like it would be more trouble then its worth.
Old Dec 4, 2019 | 10:21 AM
Couple of reasons. Real-time tuning with modern software. Full complement of motorsports features. Closed loop using wideband lambda. And no factory-inspired firmware with loads of tables, scalers, and flags to sort through. Much better tuning interface than TunerPro and the logging, tuning, and configuration functions are all in a single piece of software.
I'm also a LINK dealer and we are developing kits for the TPI and TBI. And yeah it's not for everyone - it's about three times the price of the EBL. But you have to pay to play. And it allows a clear upgrade path for running DIS or switching to an LS engine, etc. The LINK can do all that and more.
GD
Old Dec 4, 2019 | 10:43 AM
dabomb6608's Avatar
Be sure to share info once development gets further along. I'm always interested in reading about new stuff in the tpi tuning world. They certainly seems full of features and I didn't mean to come off like I was thinking otherwise .I think that my original observation came from when reading some features online. Some are not "usable" on these older setups due to limited sensors available on them.
It definitely would open the path to ways to incorporate them though. For instance traction control. If you could install a LS-4th gen rear, or aftermarket rear, with some speed sensors at each wheel and then figure out a front wheel speed sensor setup then you could use a feature like that to its fullest. Or as you mentioned, going the DIS route. Which is something I would love to do on my FIRST setup.
Cost will be the biggest hurtle. Not that I don't think it would sell. But it seems that the third gen niche just doesn't have the numbers in terms of people doing big and off the beaten path SBC fuel injected builds. Most seem to LS swap or throw a carb on top. Personally, I like being different in that regard. As I said, please share once you get moving on that. Even the install of the standalone unit. I look forward to learning more about it.
Old Dec 4, 2019 | 02:32 PM
I have a LINK Storm installed and running in my 86 Trans Am daily driver. We built a prototype harness adapter using the ECM header for the MAF TPI and TBI units. Everything works including timing control using the stock distributor. Only changes made were to set the base timing to 10 degrees and re-route the wire from the knock sensor to the output wire from the knock module (raw knock signal directly to the LINK) as it has on-board knock sensor control. We are looking at doing that with a plug-in adapter if we can source the module plugs. No header re-pin like the EBL. It plugs in using the stock pinout (I had to reverse my EBL pinout modifications).
And yeah - cost is definitely higher. But for those that don't want to learn obscure chip tuning, or the EBL - you can install the LINK, we can remote into your laptop and get it setup and running, then you can drive to a dyno and either have us remote tune it or if you have a tuner familiar with LINK you can have them do it. Our tuner is the VP of LINK for North and South America and we are his R&D dyno shop and where he does all his local tuning, etc.
GD
Old Dec 4, 2019 | 03:52 PM
dabomb6608's Avatar
I downloaded the PCLInk Software and have been glancing through it. Granted, there is a LOT in there. But it looks pretty nice. Being able to right click on any of the ECU settings and click "what is this?" to open a full description of that parameter is awesome. Obviously it would take a decent amount of research and time to make the conversion if someone was wanting to do all the tuning themselves as opposed to having a local tuner or someone from the company do a remote tune. But it looks very do-able for someone with previous tuning knowledge. Being able to find a tuner that can do more modern tuning software is a plus as well. Most shops have never heard of EBL/Dynamic EFI let alone tuned a TPI/TBI vehicle. Not saying EBL is a bad product, I've been very happy with it.
Sorry to hijack your for sale thread. I'll quit bugging you about the LINK ECU in here.
Old Dec 4, 2019 | 04:06 PM
Yeah for sure - in the software the help function is really sweet. As you noted simply right-clicking on anything gives you the "what's this?" option.
Pull up one of the base maps included with the software and check out the maps and the 3D table manipulation. Use the arrow keys to navigate the map, and play with page-up, page-down, shift+page-up, shift+page-down, and if you hold shift you can rapidly highlight entire rows, columns, or blocks of table. Try shift+H and shift+V for interpolation. There are other functions like extrapolation and smoothing also. And like the EBL it has a "mixture map" that tracks how far off the AFR is based on logs and then the suggested changes can be applied directly to the fuel map.
GD
Old Dec 18, 2019 | 10:11 AM
Bill Chase's Avatar
Where are you located.
GD
Old Dec 18, 2019 | 12:02 PM
Milwaukie, OR (basically SE Portland). I can also install the EBL and dyno tune the car if someone were so inclined.
GD
Old Jan 16, 2020 | 12:26 PM
Kitttransam's Avatar
Car: 87 trans am gta /89 chevy corvette
Axle/Gears: 3.27 / 3.07
Do you still have it for sale? Would the pin out be the same on a corvette? And does it come with that info?
Old Jan 17, 2020 | 10:59 AM
I don't know about the Corvette. Don't those have entirely different ECM's under the hood that are weather-proof? I believe those use different connectors. If you want to post a pic maybe?
GD
Old Jan 17, 2020 | 11:07 AM
GD
no mine is an 89. Last year of maf and it’s the 1227165 ecm under the dash. Only 90-91 tpi speed density had it under the hood.
Old Jan 17, 2020 | 11:14 AM
Ah I see. I did a clutch on a 90 a while back and noted it was totally different.
In that case yes - if it uses the 7165 currently then this EBL will work for you. That's what my 86 originally used.
GD
Old Jan 18, 2020 | 08:14 AM
Ok I’ve been looking into getting one anyway. If you still have it I’m just waiting to get tax returns. I mean if someone else wants it and I take too long go ahead and sell it. But if you still have it by then I’ll get it from you.
Old Apr 27, 2020 | 07:56 PM
bigbrother's Avatar
Car: 89 formula 350
Engine: tree fiddy
Axle/Gears: Borg warner 9 bolt with 3.27s
is the EBL still available?
Old May 4, 2020 | 05:30 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Is this everything needed (except a lap top) for tuning an '89? Sorry, this is new territory for me...
Old Jan 17, 2021 | 06:10 PM
89onlyZ51's Avatar
Car: 1987 Corvette Conv
Engine: Callaway Twin-Turbo
Transmission: Doug Nash 4+3
Axle/Gears: 3.07 Dana 44
pm sent - been awhile, but still happen to have the EBL setup for sale?
jjcuff1
Jul 3, 2013 11:25 AM
cdawg
Feb 14, 2012 02:00 PM
Screamin86
Oct 5, 2011 06:54 PM
randy4762
16
Aug 25, 2007 08:49 PM
BP89IROC
Feb 27, 2002 05:33 PM
