Throttle Body
Old May 21, 2006 | 01:37 AM
AmorgetRS's Avatar
Throttle Body
I am looking for the Throttle Body for a 88 Trans Am.
Old May 21, 2006 | 12:02 PM
rcarideo's Avatar
Car: 1985 Corvette
Engine: 5.7L TPI
Transmission: Richmond 6 speed manual
Axle/Gears: final drive 3.73
Throttle body
I have a 89 formula. I have two TBI setups you can choose from cheap. E-mail me at racrideo@hotmail.com
Old May 21, 2006 | 12:19 PM
AmorgetRS's Avatar
Sorry, I am looking for the TPI Throttle Body, sorry for the confusion.
Old May 28, 2006 | 09:25 PM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
I got one $60 shipped.
Old May 28, 2006 | 11:14 PM
AmorgetRS's Avatar
Is it for a AT or a 5-speed? Do you have pics?
Old May 28, 2006 | 11:15 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Makes no difference, the TPI setups were same for manual and automatic. I dont have pics right now since its still in the car, its out of a Trans Am, I can get some pics by tommorrow.
Old May 29, 2006 | 12:03 AM
AmorgetRS's Avatar
Yeah, that is what I thought, too. What year did the switch the style then? My TA doesn't have the same TB as the 91 I have one off of, or the 89 IROC I got pics of.
If it matches the style of mine I will buy it.
Thanks,
Douglas
Old May 29, 2006 | 09:30 AM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
The only thing that changed from 89-91 in TPI was that in 90' they went from MAF to Speed Density. There should be no difference in Throttle bodies. If anything is different I would say that one of your throttle bodies is aftermarket. If you could give me a pic of the the TB that looks different I could tell you what the deal is.
Old May 29, 2006 | 10:22 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
There is a difference from the 85' - 88' and the 89' - 92' Throttle Body. The Throttle Cable Type and the mount for the cable which is part of the shaft cannot be changed. However, if you change the cable to the new style that would probably work for you. Good Luck!!
Thomas
Old May 29, 2006 | 10:32 AM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Yes that is true, but he is talking about something different from 89-92. There is no difference from 89-92.
Old May 29, 2006 | 11:43 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
As I stated above what you are saying is true about there being no difference between 89' - 92'! However, unless I am reading this thread wrong they are requesting a Throttle Body for an 88' Trans Am which is again different from the 89' - 92' type and I did not want them to go through the hassel of getting the wrong one.
Thomas
Old May 29, 2006 | 04:03 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Yes, that is right he is looking for an 88' TB. I have 8 complete TPI setups ranging from 85-92. I can get him an 85-88 style throttle body no problem.
I can make sure it is an 88' before I send it to him.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
