need a couple tpi parts
Old Jun 26, 2006 | 11:33 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
i need some tpi stuff. i need the tpi base runners and plenum and fuel rails. i dont need any injectors or fpr or anything just need the items i listed. lmk what you got. im talking chep now i dont care what condition the items are in either. but i will need pictures.
Old Jun 27, 2006 | 03:54 PM
fbodyguy86's Avatar
Car: 92 camaro rs
have an intake manifold for pre 87 heads that has a atripped bolt for the thermostat but has a heli coil in it was told it worked fine but got one for the 87 and up heads anyway so didnt need it lmk what you think
thanks
Old Jul 5, 2006 | 10:45 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
im converting from tpi...so pretty much anything you need. my manifold is for pre 87 heads though. runners have no dents, i have an accel billet 2x58 throttle body. all the sensors etc.
Old Jul 7, 2006 | 07:06 AM
Car: 88 IROC
how much for the throttle body?
Old Jul 7, 2006 | 10:51 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
I have a TPI base from an 86 Iroc. $25.00 shipped............jt
Old Jul 7, 2006 | 11:06 AM
cheese_kake's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
I have every part for the TPI setups. 85-87 and 88-92 . Complete sets are $400 shipped but also include wiring harness, ECM and injectors, and if needed distributor can be added for about $20 more.
Old Jul 7, 2006 | 01:28 PM
ZZ4 86 Z28's Avatar
well it sells at summit for 550, so i can throw it to you for 250 plus shipping, and i can include the original reciept that came with it from summit too...just in case you like to keep track of things on file or whatever. let me know.
Old Jul 7, 2006 | 08:10 PM
Car: 88 IROC
sorry man i cant go that high, they say aftermarket throttle bodys yield minimum gains...
Old Jul 8, 2006 | 04:24 PM
ZZ4 86 Z28's Avatar
by itself it will give a minimum gain, but without it, a built tpi setup means nothing. how about 200?
Old Jul 8, 2006 | 04:27 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
I have a stock 89 no 9th injector I will do 190 shipped.
Base/runners/upper/water outlet/fuel rails factory TB is 40 more.
Old Jul 8, 2006 | 08:34 PM
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Until your valvetrain is superior to your intake its pointless. I've found that alot of people didnt need to go to 52mm or 58mm until 350+rwhp, and thats if you were patient enought to get the TPI to make that much power.
Old Jul 9, 2006 | 04:06 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
'87 Base, runners , plenum and fuel rails..with or without the CSI, 175 shipped.
PM with email addy, or email me if you want pics.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
