Alternator and brushes
Old Mar 28, 2007 | 01:43 AM
Guest
Guest
Posts: n/a
Hi,
I want to buy the brushes or maybe the complete alternator.
It must not be a GM product, aftermarket would be good.
Which one is the best source? Can you tell me a company?
For my 1984 Trans Am.
Thank you,
Laszlo
Old Apr 8, 2007 | 01:04 AM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
Re: Alternator and brushes
I have a complete alternator with excellent brushes. the silinoid is bad. but the rest of the starter works gr8 it even works, but sometimes it takes 3 turns to start it. I did sray gray paint on it to save it from rust in case i needed it for spare parts. make a offer and it's yours plus shipping it is off a 89 TPI auto 700r4 trans, but all the inner parts are interchangable.
Old Apr 12, 2007 | 05:38 AM
Guest
Guest
Posts: n/a
Classic Industries alternator question
Hi,
I bought an alternator from Classic Industries.
I did not try to install it until now but I noticed the following:
The gap on the pulley is thinner than the gap on the original
alternator. The original is about 11mm wide, this one is 9mm.
I think it will damage the drive belt because the edges of the pulley
are cutting and not round. The belts are 11mm wide.
What should I do? Can I just remove the pulley from the original
alternator and put it onto the new one? Are they compatible?
Please find attached the picture of the new alternator.
Description on the website is:
ALTERNATOR 1983-1984
OEM 100 amp exc Cross Fire Injection
The original one has black plastic fan or what.
Thank you,
Laszlo
Old Apr 12, 2007 | 05:44 AM
Guest
Guest
Posts: n/a
Re: Classic Industries alternator question
An other question: voltage of the new alternator is set to 14.6V.
Is it not too much? Usually it is 13.8 - 14.4V. Or that 0.2V plus does
not matter?
Thank you,
Laszlo
Old Apr 12, 2007 | 11:01 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Nope, 14.6 is perfectly fine.
Old Apr 12, 2007 | 02:27 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
you should change the pulleys. Put the original one back on, clean it up and paint it so U don't have messy stuff.. U will need air tools 2 make it easy or some auto part shops will do it for free. Do not clamp the pully to try to loosed the nut, this will cause it to bend and wear out your bearring. if you can, try 2 use some liquid wrench and hold a part of the middle if you can by wedging a screw driver in it and use a hammer to hit the end of your ratchet to looswen the bolts.
Old Apr 13, 2007 | 07:48 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
just go to carquest if you have one local they will do it if not then geta set of the cheap rubber strap wrences from walmart ($7 or so) and then use a socket to remove the retaining nut don't remember size 1 and 1/8 or 1 and 1/4 then install the old pulley like it was mentioned just clean and paint to make it look aftermarket just sandblast then paint with gold cadium or zinc paint available from some auto parts stores or Classic industries.
Old Jun 26, 2007 | 12:56 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i got an alternator from an 85 camaro 305. its seems to be in great condition. i havent used it in a while but i could give it to you for chea. message back on this thread or aim me at kowboy059
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
