350 TPI Injectors
Car: '89 IROC convertible
Engine: 355 TPI
Axle/Gears: 3.45? Posi
350 TPI Injectors
Looking for 8 fuel injectors for '89 IROC, good working condition. Need to be at least 22 lb/hr. Don't necessarily need new, just solid.
Engine: 355 TPI
Re: 350 TPI Injectors
Ok, what kind of information/specs do you have? How new, how many miles? Any pics, I'd really like to see some before spending that much on used injectors. Have they been cleaned/flow-matched? Thanks.
I have 8 '89 Formula 350 TPI injectors. One is low OHM all the rest are good. I took them out of my '89 that had 70k miles on it. It actually didn't run that bad but you could hear a puffing sound coming out the pipe on one side.
I'll take $600 including shipping.
Let me know.
Let me know.
Engine: 355 TPI
I sure hope that wasn't $600 for 8 moderately used injectors, 1 of which doesn't look promising......
Car: 89 Firebird Formula 350
Engine: 350 tpi
Jegs has a set of Accel 23# injectors for around $300 new. I put a set in when mine went bad 2 years ago and I have not had any problems yet. The extra pound won't hurt b/c of the fuel pressure regulator. Plus as you do more mods you may want it. Good luck.
Also, your car stock should only need 19# injectors (which jegs also sells). The 350 took 22 pounders.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
I have a good set of 24 lb Accels. You can see them at this link......
https://www.thirdgen.org/forums/engi...e-springs.html
They have been cleaned and flowed.
