Looking for a working 700R4 or complete 5/6 speed Swap
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Im looking either for a working 700R4 out of a 87 - 92 camaro or firebird or a complete 5/6 speed swap with all related parts.
I live in northern Delaware and wouldnt mind driving a bit to get everything if the price is right.
Email me at iggy166@juno.com or AIM me at iggy1718
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Looking for a working 700R4 or complete 5/6 speed Swap
If you need the crossmember, I have a Spohn T56 unit.
Car: 87gta 88gta 88marovert
I just bought a 89 camaro 305 5 speed car to parts out. Engine is knocking but was running so I deed test drive it and checked out the trans. The 5 speed stuff is all there and is working shifted smoothly with no grinding. $600 for the works picked up
Car: 68 Chevelle w/ TPI, 87 Formula 350
Transmission: 700 R4
Axle/Gears: 3.55 / 3.42
I have a 700r4 from an 87 TA if still interested
Hi, I have a custom built 700r4 with all the good parts inside. It is in my El Camino and is great behind my 406 full roller motor. It has only driven around locally for about 1000 miles. I am going to a 5 speed set up and will be pulling it out shortly. email me if you are interested and I will make you a real good deal.
also have a t56 Swap...from 97 TA...all you need is pilot bearing, pedals and crossmember. I have a 4th gen crossmember. Might be able to do soemthing with that....
I will have a 5 speed conversion I will be pulling out in a few weeks. I am switching to an automatic.
It will include T-5 trans (85,000 miles), Hurst shifter, Hayes clutch (1800 miles) Billet steel flywheel 153 tooth ( approx. 500 miles) (I forgot the brand but I have the receipt for it so I can find out), bellhousing, pedals and all other parts needed . The only thing you will need is the crossmember( I need that for the 700 R4). I probably will be asking in the neighborhood of $750 due to the flywheel/clutch being basically brand new. You can even come and test drive it before I pull it out( shifts smooth no problems). Only reason for switching to an automatic is I prefer automatic over stick. I am located in Hatboro,PA probably around 1 hour from you so if you are interested Pm me and I'll give you my number.
OK I PMed the ones Im interested in. Keep the options coming?
Car: 88 Camaro. 99 Grand am.
Transmission: t-5
Axle/Gears: 3.08
If you are still interested i have a rebuilt 700r4 with torque converter that has been rebuilt for $1000 i can produce reciepts. The tranny and torque converter have only been in the car for three months and been locally driven. P.M me for more details
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
