need a cam for l98
Old Nov 12, 2009 | 01:20 AM
patricksmithahh's Avatar
Car: 90 corvette
Engine: l98
Transmission: built 700
Axle/Gears: stock
need a cam for l98
hi i have an aluminum headed l98 from a corvette i want to put a cam in it but idk which one...i plan on doing heads in the future but not now
so i guess i would need a fairly mild cam i want the best one that can be used for a stock head l98
if you have a write up or link on how to install that would be great too cause idk how
Old Nov 15, 2009 | 10:26 PM
tpi88camaro's Avatar
Car: 1980 Regal
Engine: 383 Superram
Axle/Gears: 12 bolt w/ 3.31 posi
Re: need a cam for l98
IIRC, all '88 and up 305 and 350 TPI motors used the same roller cam.
Old Nov 15, 2009 | 10:31 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
idk about that, im almost sure the 305 auto's had the small cam. The 305 Manuals had the 350 cam, which allowed them to red line at 5500
Old Nov 15, 2009 | 11:10 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
dont want stock tho.....im talking aftermarket what would be the best for what i want
Old Nov 16, 2009 | 04:10 PM
Car: 1980 Regal
My bad, '88-'89 305's and 350's used the same cam (part # 10066049) whether is was auto or manual
'90-'92 305's and 350's used a little smaller cam(part #10111773) whether it was auto or manual
Old Nov 16, 2009 | 04:21 PM
Car: 1980 Regal
For a computer controlled engine, try one with duration at .050 lift of 202-205 intake and 206-214 exhaust. Most cams with these figures will have between .415"-.460" lift with stock rockers. Most of these cams will be emissions legal. You didn't say if your engine was efi or carb or whether it is computer controlled. Doesn't matter it will run smooth regardless. Hope this helps some.
Old Nov 16, 2009 | 05:01 PM
Engine: 350 Tpi
Axle/Gears: 3.08
where are you getting this info?
Old Nov 16, 2009 | 09:35 PM
Car: 1980 Regal
Pages 75 and 76 of CAMARO PERFORMANCE HANDBOOK by David Shelby. The book with the blue Z28 on the front cover.
Old Nov 16, 2009 | 10:08 PM
Car: 90 corvette
Engine: l98
Axle/Gears: stock
that does help thankss...and im sorry didnt mention but its the same engine in my avatar just a tuned port aluminum head l98
Old Nov 16, 2009 | 10:45 PM
Engine: 350 Tpi
Axle/Gears: 3.08
why does the 305 manual and l98 rev higher than the lb9 auto?
Old Nov 16, 2009 | 10:49 PM
Engine: 350 Tpi
Axle/Gears: 3.08
http://www.gmtips.com/3rd-degree/dox/tips/cams/cams.htm
All 305 TPI (LB9) engines (1985-1992) came with one of two basic cam grind profiles. An easy way to identify the type of cam on an LB9 car is to look at the tach: the lesser cams have a yellow line at 4500 and red line at 5000; the hotter cams have a yellow line at 5000 and red line at 5500. All camshafts 1987 and later use hydraulic roller lifters
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
z28guy134
Sep 1, 2015 11:50 PM
