TPI Throttle Body
Old Sep 6, 2011 | 08:45 AM
phatazzmarine's Avatar
Car: 85 Camaro Z28
Engine: 5.7
TPI Throttle Body
Hey guys, its been some years since i been on here, but i am looking for a throttle body for a 91 Z28 TPI motor. Im hoping it comes with the sensors and stuff on it as well. I took mine off to clean it and when i tried to take the lower cover off for the IAC gasket, 3 bolts broke off and im just looking to replace the one i have. Let me know what you have, and if the price is good, maybe ill go for an aftermarket one if you have it. Thanks
Old Sep 7, 2011 | 01:11 PM
marokid's Avatar
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
Re: TPI Throttle Body
how much are you looking to spend?
Old Sep 7, 2011 | 01:26 PM
Car: 85 Camaro Z28
Engine: 5.7
Im not sure on a price. I am just trying to see what someone has and what options i have. I need to change mine because my TPI unit is messed up and i need something new/good condition used unit to replace it with.
Old Sep 12, 2011 | 05:58 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
That's real common becouse of the heat of the coolant corrodes the bolts. You can spray on liquid wrench and the wiggle the back and forth with small vice grips, if the y are flush I have spot welded on nuts and got them out that way. I have a new lingenfelter but you would need to use your tps and iac and lower plate..
Old Sep 12, 2011 | 06:57 PM
Car: 85 Camaro Z28
Engine: 5.7
Yea, i know i can get them out but i rather just replace the IAC housing on the bottom. That is why im trying to just replace the whole assembly. How much you asking for the TPS unit, shipped to 33162.
Old Sep 12, 2011 | 07:02 PM
Engine: Lb9
Transmission: M20
lingenfelter 58mm throttlebody located in classifieds here with pic
Old Sep 13, 2011 | 11:06 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I have a stock '89 from L98 with sensors and tpi butterfly. $125 shipped. PM for details
Old Sep 20, 2011 | 09:30 PM
Engine: Lb9
Transmission: M20
Must not be sloppy in the throttle shaft for 125, ive had 3 off ebay until I got one that didnt have a bunch of slop in it.
Old Sep 21, 2011 | 09:15 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
No slop, whatsoever. Sensors are relatively new. I am an original owner. Had one throttle body replaced by dealer. This is that second one. I am doing an LS swap and parting out.
Brian
Old Oct 3, 2011 | 03:34 PM
L98IROCZ1987's Avatar
Car: 1987 IROC-Z Z28
Axle/Gears: 3.70 9 bolt
50$
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
