TPI Stuff
TPI Stuff
Needed for 92 TPI:
- throttle cable
- Aluminum thermostat housing (possibly found)
- Good cold air induction setup for Firebird. Like it black so it looks factory.
- throttle cable
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Re: TPI Stuff
I have just about everything TPI you may need. I definatly have everything your asking for in your post. What are you looking to spend for all of it? Make me an offer.
Re: TPI Stuff
OK, found I need a lot of little fittings and such. Hopefully you guys can help me out using some pics.
First pic - - I have the ECM temp sensor screwed into one port, what are the other 2 for? There are a couple of harness plugs nearby -- pics available. And what about the little plug in the block below?
Third pic - - what is that little plug for, and how about that block-off plate?
Re: TPI Stuff
list updated. Also, anybody seen one of these? It was on the Player's car, I believe it's a fuel pulsator. Not sure if it was factory or not.
Re: TPI Stuff
Needed for 92 TPI:
- Steel fuel lines and flex lines from manifold to frame
- Good cold air induction setup for Firebird. Like it black so it looks factory. (Deal pending on one)
- TPS & IAC plugs - - mine have been cut out & wired for a different throttle body.
- IAT sensor? Does a 92 even use one, and where does it go?
- Harness from distributor to coil.
- All the stuff in post #11 below.
Might be more things to come up, will keep posted.
Transmission: Pro-built 700R4
Re: TPI Stuff
Steel fuel lines and flex lines from manifold to frame- Aluminum thermostat housing- TPS & IAC plugs - - mine have been cut out & wired for a different throttle body.- Harness from distributor to coil.Have all this.the wireing am about to take off my 91 camaro.Harness from distributor to coil. of anoter car. Let me know thanks
Re: TPI Stuff
Cleaning up the garage today and I came across the original thermostat housing from my car. It is deffinately from a TPI motor if you are interested. You can have it for $15 shipped.
-Eldon
-Eldon
Re: TPI Stuff
I will let you know when posted.Thanks ,
Jason
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
