86 engine harness tpi
Old Apr 29, 2018 | 09:50 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Need a 86iroc engine harness 305tpi
Old Apr 30, 2018 | 03:01 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: 86 engine tpi
I have a tpi harness from a 1987 GTA if it will help, or are you wanting to stick with the big cap HEI?
Old Apr 30, 2018 | 06:38 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 86 engine tpi
Like to stay with what it has if I can.
Old Apr 30, 2018 | 08:51 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 86 engine tpi
would that work in my 88 formula? It's a 350tpi
Old May 1, 2018 | 10:04 AM
jkris53406's Avatar
Re: 86 engine tpi
Yes
Old May 1, 2018 | 01:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 86 engine tpi
FYI: 1987 and 1988 Engine bay wiring is NOT the same !! 87 Uses and ENGINE and a seperate ECM harness,... the 88+ cars use 1 HUGE harness for the Engine AND the ECM wiring combined. ( Headlight harness also changed from 87 to 88. )
I've got an TPI ECM harness from an 86 IROC automatic. You can see the details here:
https://www.thirdgen.org/forums/engi...e-harness.html
If you need an ENGINE harness,.... I should have one of those too, but I'll have to check into that t be sure.
Send me a PM that includes your ZIP for a shipping quote if your interested.
Old May 28, 2018 | 01:50 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: 86 engine tpi
i sent a pm to you a while back. I still need the harness for the 86 tpi and one for a 88 tpi.
Old May 31, 2018 | 12:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 engine harness tpi
There’s one on Facebook good price
XrayTedd
Nov 5, 2019 09:00 AM
Alice89
Oct 12, 2018 06:40 PM
vortech305
Mar 23, 2001 03:32 PM
AC
Mar 19, 2001 03:51 PM
