86 tpi engine harness
Old Apr 6, 2019 | 08:46 AM
Mikegh's Avatar
Car: 1985 Z28
Im looking for a 86 camaro tpi engine harness in good shape.
Old Apr 6, 2019 | 10:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 86 tpi engine harness
I think the 87 harness is the same too. Hth
Old Apr 6, 2019 | 11:01 AM
Mikegh's Avatar
Car: 1985 Z28
Ok thanks I have a mixed up build Its 1985 Z28 with 87 corvette L98 and 88 camaro serp belt setup
Old Apr 6, 2019 | 11:06 AM
Engine: Lb9
Transmission: M20
If you have the alternator on the drivers side you might want to look at a 88-89 harness. The 89 harness needs to have the ninth injector tuned out of the ecm. No wiring for it. But with the vette l98 you should tune anyways. There might be differences between c100 you will have to verify and repin if needed.
Old Apr 6, 2019 | 11:11 AM
Mikegh's Avatar
Car: 1985 Z28
I still have the 85 c100 part of the harness so I was going to use that and use the vette ecm with an 88 camaro prom. I was thinking the alternator wiring is something I can just make up. I think the 88 89 harness has both harness all together?
Old Apr 6, 2019 | 01:10 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
I have one off a 89. Good shape. Pm me.
Old Apr 6, 2019 | 10:32 PM
Engine: Lb9
Transmission: M20
There you go a 89 harness just compare c100
http://www.austinthirdgen.org/index.php?pid=19
Old Apr 7, 2019 | 12:25 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Ya',...... Using an 88 ECM and Serpentine Accessories,..... You want an 88 / 89 harness.
82-87 cars used an ECM harness and a separate ENGINE harness, but in 88 they were both combined into 1 HUGE harness.
Old Apr 8, 2019 | 07:57 AM
Mikegh's Avatar
Car: 1985 Z28
So I guess 88 would be best I have the 9th injector and no vats
Old May 21, 2019 | 08:53 AM
LS IROC's Avatar
Car: 1986 IROC
Engine: Texas Speed LS 427
Transmission: 4L80
Axle/Gears: Hawks 8.8 3.73
I have a wiring harness I took out of my 86 IROC, it’s in good shape I also have the ECM.
Old May 21, 2019 | 07:27 PM
Mikegh's Avatar
Car: 1985 Z28
I found one already but thanks
Cold Dark Shado
Mid-West Region
Jun 4, 2003 10:33 PM
iroc_cragg
Apr 16, 2003 07:20 AM
iroc_cragg
Feb 22, 2002 08:28 PM
