Lo3 / Lb9 ???
Old Apr 24, 2002 | 06:48 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
Lo3 / Lb9 ???
1991 5-speed, LO3 [RS] and 1991 5-speed,LB9 [B4C] use the same block, pistons,flywheel?
The LO3 RS has 32,000 miles on it and the RS B4C has over 200,000 miles. Can we use the LO3 short block with the B4C's heads,cam and injection system. Will the change keep the B4C a true B4C?
GTAFOX
Old Apr 24, 2002 | 12:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, the short blocks would be the same.
But, in the strictest sense, it wouldn't be B4C anymore because the numbers wouldn't match.
Functionally - identical.
Old Apr 24, 2002 | 03:16 PM
iroc22's Avatar
Just keep the original B4C engine, and swap all the LB9 parts onto it. It will make it run great and then you can always swap back to the matching #'s block whenever.
Old Apr 26, 2002 | 12:13 AM
Spdfrk1990's Avatar
The blocks are not the same the LB9 is made for a roller cam and the LO3 is not. If i was you i would take the LB9 block and rebuild it and maybe put a stroker kit in it like a 383.
Old Apr 26, 2002 | 12:21 AM
Spdfrk1990's Avatar
It wont run right with out the roller cam specially since u have speed density
Old Apr 26, 2002 | 12:47 AM
RSRagtop's Avatar
LO3 have roller cams, truck LO5s do not. All 305 TBIs in Camaros came with roller cams.
Old Apr 26, 2002 | 01:05 AM
Spdfrk1990's Avatar
I have a book on tuned port injection and it says when swapping from a lo3 u cant use the same block cause they dont have roller cams.
Old Apr 26, 2002 | 02:10 AM
shotgun's Avatar
Car: 89rs
that book is a crock of ****
Old Apr 26, 2002 | 10:39 AM
Spdfrk1990's Avatar
well i would be surprised if my LO3 has a roller cam and lifter when i take it out.
Old Apr 26, 2002 | 03:05 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
A good rule of thumb: If you have centerbolt valve covers, you have a roller valve train. (in most all cases)
Old Apr 26, 2002 | 03:55 PM
Spdfrk1990's Avatar
Old Apr 26, 2002 | 04:03 PM
Spdfrk1990's Avatar
Well thats kewl if my block is roller but i dont want to use the 305 again ne way but in his case it might be good.
Old Apr 26, 2002 | 05:47 PM
iroc22's Avatar
Dude its a roller block. Im 200% sure. I've had mine apart many times.
The good rule of thumb is only applicable with passenger cars. Trucks had centerbolt valve covers but flat tappet cams.
Old Apr 26, 2002 | 07:29 PM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
Just check Helms manual and the it is a roller motor. What will we need off the LB9? Are the heads the same?Exhaust manifolds the same?Thanks for the help!
GTAFOX
Old Apr 26, 2002 | 07:45 PM
Tas's Avatar
Tas
GTAFOX
305 TPI has better heads, exaust manifolds, and sometimes a better cam.
Old Apr 26, 2002 | 10:52 PM
iroc22's Avatar
Yup and the good cam was G92 TPI's up to '90 and in 91-92 all the 305TPI's got the bigger cam.
Old Apr 27, 2002 | 05:35 AM
GTAFOX's Avatar
Car: 92 B4C
Transmission: A4
Thanks for your help. If anyone can think of anything else that needs to go with the change over let me know. The change over will start Sunday.
GTAFOX
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
