sensors..
Old Jul 30, 2002 | 07:58 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
sensors..
hey guys i just about have the 305 tbi out and i am ready for the 350 carbed engine, well i have noticed many sensors and i need to know witch ones stay when i take out the computer and wut ones don;t. well theres the temperature sensor on the passenger side head that i eplaced a while ago and anitfreeze came out so does that one stay? also there is somthing above where the oil filter goes, and on the drivers side head there is sumtin and on the frint of the intake manifold, this one confuses me cause isn;t it another temp sensor?? oh and guys remember i am switchin to carb from tbi so i am takin ut the computer, i just need all my guages to work and stuff. thanks guys
Old Jul 30, 2002 | 09:59 PM
83 MidniteZ's Avatar
All you really need is your temperature sending unit which is probably running from your driver side head, and your oil pressure sending unit which is what i believe you are referring to located about the oil filter. It is found in three rear of the block right behind the intake manifold. I ripped my crap out a long time ago, but if my memory serves me correct there is emmission crap in the inake manifold attached to your thermostat housing. Why don't you do it this way... Figure out what you want to keep. Mark em and take everything else out and plug em.
Later
Old Jul 31, 2002 | 12:17 PM
flyway190's Avatar
Re: sensors..
Yes, that controls your gauge.
That controls your fuel pump, and if you don't have a bell-shaped sender next to your distributor, then it also controls your oil pressure gauge. There should be three prongs on it, the two farthest apart are for the fuel pump, the other one for the light or gauge.
Yes, that one's for your computer, you won't need it.
Do you also have a fan switch?
Old Jul 31, 2002 | 04:20 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Your 305 dizzy won't work without the computer. Which one are you planning on running? I have a mallory unilite on my '86 and a HEI on my '91.
Andy.
Old Jul 31, 2002 | 10:43 PM
Car: 89 Formula
Engine: Carbed 5.7
oh i know i picked up a summit hei dist. i got everything i need i am just nmot sure wunt to keep. um the fan relay? is that the thing on the dirvers side head maybe i dunno lol anyhelp??
Old Aug 1, 2002 | 12:01 PM
flyway190's Avatar
Check your driver's side head between exhaust ports 1 and 3. Should be the gauge sender there. On your passenger side in the back between exhaust ports 6 and 8, should be the fan switch.
1qk4mula
Nov 13, 2013 08:30 AM
88 Z-ROC
Dec 6, 2012 11:07 AM
fearthisinc
Mar 22, 2010 10:35 AM
ninetyone
Oct 28, 2009 11:18 AM
robster66
Aug 16, 2009 03:06 AM
