choke lights on ? and engine keeps shutting down ?
Old Jan 22, 2003 | 06:09 PM
600_dollars's Avatar
Okay the title describes the sitution .. can anyone shed some light ? and maybe give me detailed info on what i can do to fix this problem
Old Jan 22, 2003 | 06:10 PM
BTW. i have a 305 stock the stock 4 barrel carb " quadra jet?"
sorry i am pretty new to all this =o)
Old Jan 22, 2003 | 07:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The "Choke" light is really the "Alternator" light. By way of some emissions-related logic that defies comprehension by us mere mortals, the factory decided to label the light clearly so that any reasonably mechanically proficient person would be able to tell right away what part to replace. Light comes on, says "Choke", means "The alternator is not working". Makes alot of sense doesn't it?
Anyway, sense or not, you need to replace the alternator.
Old Jan 22, 2003 | 09:57 PM
okay , so why will it start again , and again .. never just completely go out ? never dim lights ...nothing it wont shut off if i completely floor the gas pedal just sounds like its "bogging" out ya know
BTW . thanks in advance for shedding light on my situation
Old Jan 22, 2003 | 10:11 PM
ctandc's Avatar
Now, I don't know if the 3rd gen CCC Q-Jet cars are this way ( I would ASSUME so,.......but you know how that goes ) but the 4th gen Monte's with the CCC Q-Jet have the low oil pressure sensor wired into the choke circuit. Sometimes a choke light being on also means LOW oil pressure.
Just a FYI......
Old Jan 23, 2003 | 09:29 AM
84TAProject's Avatar
I love the oh so easy to understand lights in my dash
When my choke light stayed on, my voltage was also very low. Found out the alternator was indeed bad. Oh well, I was wondering why I was getting the "what the hell's wrong with you" lecture when I was driving spiritidly with 11 volts and a choke light on. Apparantly I was lucky to make it home that day. 40 miles with a weak alternator is not a good thing
Old Jan 23, 2003 | 09:41 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Don't know if this will help but...
My 83 V6 car had the choke light which was tied into a choke heater element on the carb's base gasket. There was a gray electrical connection that tied into the harness and a 15 amp "choke" fuse in the fuse block. Turns out the fuse was blown. When the light was on the car would restart but it kept getting loaded up with Gas.
Old Jan 23, 2003 | 06:36 PM
checked all the fuses, well guess what the fuse wasnt in there + the engine fan wasnt even hooked up !?! i got all that taken care of and the car is so much better and doesnt get sluggish or overheat at all!
Old Jan 24, 2003 | 09:30 AM
MDv6man's Avatar
Car: 1983, 1986
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
Fronzizzle
Aug 9, 2015 01:15 PM
