2.8 Carb to 3.4 Carb?
Old Jan 24, 2003 | 05:25 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
I currently have a 2.8L V6 carb'd engine in my 1984 Firebird. I am thinking of going to a 3.4L V6.....though I am not sure what I would need to change on the 3.4 as I know those were all Fuel Injected..not carb'd. Would the carb and intake on the 2.8 be to restrictive on a 3.4? And would the computer need to be tweaked with the larger engine?
Any help would be great!
Old Jan 25, 2003 | 10:41 AM
Parrydise7's Avatar
Check your other post. The 3.4 crate motors from GM are built to take a carb. The fi 3.4s, as far as I can recall, are all east-west engines. Your Camaro has a north-south.
Old Jan 25, 2003 | 10:56 AM
84 Challenge's Avatar
What's this east-west and north-south thing?
Old Jan 25, 2003 | 01:32 PM
Parrydise7's Avatar
East-west means front-wheel drive (the engine is mounted sideways).
North-south means rear-wheel drive.
To the best of my recollection, those efi 3.4 engines went into front-wheel drive vehicles only.
The GM 3.4 crate motors are for a rear-wheel drive application. The 3.4 was a noticeable improvement over the 2.8 that originally resided in my Jeep.
Old Jan 26, 2003 | 02:28 AM
Jurrel's Avatar
Car: 1984 Firebird
Well the Firebird EFI'd 3.4's are all rear wheel driven adn are EFIed.....so I have no idea what that post was suppose to mean
Old Jan 26, 2003 | 10:39 AM
Parrydise7's Avatar
Yup, you are correct. There is at least one exception to that east-west rule. But, note that I did say, "as far as I can recall." I find myself saying "as far as I can recall" more and more.
Old Jan 26, 2003 | 11:36 AM
Jurrel's Avatar
Car: 1984 Firebird
Sooo....what if any difference is there with the 3.4 engine if it is mounted in a rear wheel drive car or a front wheel drive car?
Aside from the obvious drive train stuff....
Old Jan 26, 2003 | 12:55 PM
Parrydise7's Avatar
Although I think parts like the intake mani are oriented differently, I can't give you a good answer to that one. There is one other vehicle that got an efi 2.8 and that is the Fiero. I remember reading another post that said if you take the efi intake mani off a Fiero and put it on a 2.8 Camaro, the inlet is pointed the wrong way. That is about the best I can do on this one. I guess if you are going to pick up some parts at a junkyard you need to at least mentally picture how that part will fit on your vehicle.
One other thing that I just remembered. I think those front-wheel drive efi 3.4s also had an aluminum head with canted valves. I think the block (as well as the head) is different because of the valve train geometry. Didn't Chevrolet put a dohc 3.4 in a Cavalier?
And, by the way, all of this is to the best of my (fuzzy) recollection.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
spartanreaper
Sep 25, 2015 07:22 PM
rjcme
Sep 5, 2015 01:23 PM
