how much can i use from my 305??
Old Feb 17, 2003 | 07:28 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
how much stuff off of my 305 can i use on a swap to either a 383 or a 355... i know i will either need to buy new or re use the balancer/flexplate/pan etc. but i was wondering how much if anything i could just take off of my 305 and throw onto the new motor
Old Feb 17, 2003 | 11:54 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
i know someone out there has done a swap from a 305 to a 355 or 383 and knows how much i can use from my 305 in the swap...
so get to it guys!!!!:lala:
jk... LoL... i had to get this back to the top somehow!!
Old Feb 17, 2003 | 12:18 PM
pskel350's Avatar
you can pretty much use everything if you wanted to. you can even use the 305 heads and intake if you want, although im sure you know that they wont perform that well.
are you talking about accesories?
we need more infomation on what your planning on doing...ie. fuel injection/carb, etc.
Old Feb 17, 2003 | 12:58 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
sorry... i should have gone more indepth into it... it will definatly have the TPI setup from my 305 put back on... and 24 lb injectors a buddy has for a while at least... what i was referring to was the accessories such as balancer? flexplage? flywheel? oil pan? type stuff... i know the TPI stuff will bolt on fine... i might have to put the stock heads back on until i get a chance to make the money for the heads i am planning for it... and i know the stockers will bolt back on fine for the breakin process... starve it a little but it will work...
Old Feb 17, 2003 | 01:45 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if u do a stroker type motor and use the balancer off the 305 make sure u have the two with each other when the machine shop balances it for you.
Old Feb 20, 2003 | 08:36 AM
Pontiacman's Avatar
If you build a 350 you can use the original flywheel or flexplate, and the original harmonic damper. If you build a 383 you will need the flywheel/flexplate and harmonic damper from a small block 400. The 305/350 cranks were internally balanced, but the 400 crank was externally balanced. Therefore you will need an externally balanced harmonic damper and flywheel/flexplate. If not it will shake like crazy and you may even break parts.
Old Feb 20, 2003 | 10:30 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
And adding to what Pontiacman said, if you get a 383, you'll need a new pan too for stroker clearance.
Tom
Old Feb 20, 2003 | 11:39 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
yeah i knew i would need a new pan for the 383... i just didn't know if the regular 305/350 stuff would bolt on right... from the looks of my small budget i am gonna go with the 355 now... i am probably gonna find a 350 short block in a bone yard though so i can just throw that pan/balancer/flexplate/dampener on there and minimize downtime...
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
