ls1 performance question...
Old Mar 4, 2003 | 06:32 PM
87rediroc's Avatar
Car: 87 Iroc (summer only)
Engine: 5.0 TPI
Transmission: 5 speed
I did a search, but could not find any comments on how LS1s performed once installed in thirdgens. Any rwhp and 1/4 mile numbers available? Just curious to see the results this swap yields. Thanks!
Old Mar 4, 2003 | 06:59 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
The LS1 is an awesome performer in thirdgens. Believe it or not people are running mid 12's without mods.
Slightly modded engines are running high 11's/ low 12's putting down mad hp and still getting 20mpg around town.
I suspect I will be capable of the aforementioned times with cam and converter.
Check out http://www.speartech.com/track.html
I drove that car. It's an animal.
Old Mar 4, 2003 | 07:18 PM
87rediroc's Avatar
Engine: 5.0 TPI
WOW! Thanks wm_sorg, that is very impressive. Now if I could only find a cheap ls1 engine lying around...
Old Mar 4, 2003 | 08:52 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The LS1 is a very sweet engine. GM rated the LS1 Camaro’s and Firebirds at the rear wheels. So the stock HP rating 300-325 HP depending on which year LS1 you get is how much it puts out at the wheels.
This site has dyno numbers of a thirdgen with a LS1.
http://www.fbody.com/members/LS1IROCZ1/
Old Mar 4, 2003 | 11:10 PM
Guest
Guest
Posts: n/a
All engine HP ratings are at the flywheel. GM just changed the numbers, for whatever reasons they had. At least they didnt over-estimate, like Ford.
Old Mar 4, 2003 | 11:29 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I have heard rumors that GM rated the Camaro LS1 at the wheels to lower insurance rates.
Old Mar 4, 2003 | 11:45 PM
Guest
Guest
Posts: n/a
Rumors not true. This comes up a million times, the testing is per a standard that hasnt been changed. Its not new about manufacturers lowering HP ratings for 'insurance' purposes though... or other reasons.
Old Mar 4, 2003 | 11:50 PM
zerotosixtyV8's Avatar
Car: Camaro
Actually I heard that about the LT1 but it's not true either, a buddy of mine with an LT1 dyno'd it stock and only put 260 HP to the rear wheels
Old Mar 5, 2003 | 12:53 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I believe they only started rating rear wheel HP on the Camaro & Firebird LS1's. I think, I may be wrong but I though LT1’s stock HP numbers are rated at the flywheel. But all Camaro and Firebird LS1’s are rated stock HP at the rear wheels.
Old Mar 5, 2003 | 01:25 AM
Car: Camaro
possibly. A Z28 is just as fast as a corvette is from a dig. I've seen it all too often. They rate the Z at 320 HP and the Vette at 350
Old Mar 5, 2003 | 02:17 AM
wm_sorg's Avatar
Ratings fot LS1s are depeneding on what year you have. 01 and 02 ls1 engines have been rated anywhere from 310 to 330 rwhp on average. For thirdgens it is the ultimate swap because it is about 150lbs lighter than legacy sbc engines. More power less weight. You can not loose.
Old Mar 5, 2003 | 07:54 AM
87rediroc's Avatar
Engine: 5.0 TPI
Thanks!
Elephantismo
Feb 13, 2019 12:51 AM
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
86White_T/A305
Sep 21, 2015 05:28 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
