They can't answer my question: can you??
Old Mar 5, 2003 | 08:50 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Here is a link to a crate motor I'm considering. But, in the descrip, it says it works best on 87-89 camaros. I have 91 TPI. When I asked them why it would work on 87-89 better, the tech dept told me that it would fit my car but the engine was designed for those previous years. Anyone know why?? What is the difference between the 87-89 350 TPI vs the 91 TPI??
http://www.goautocenter.com/300hp_tpi_1987-89.htm
Old Mar 5, 2003 | 11:09 AM
kevinc's Avatar
Car: 1982 Z28
The newer TPI engines came with flat-top pistons, yielding higher compression than the older engines' dished-top pistons. Your fuel and spark tables are designed for this...putting in an engine w/ less compression will cost you in power output.
Old Mar 5, 2003 | 02:07 PM
thanks ....thats what I needed to know. It was either that engine or the 350 TPI w/ Vortech heads from SDPC. GUess I know which way to go now.
Old Mar 7, 2003 | 07:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unfortunately, it's just not true.
The later TPI systems were speed density, vs. the mass air flow of the earlier. Compression was always 9.3:1.
About the only difference inside the engines was the cam, and those differences were slight. However, the MAF system is more forgiving about changes to the basic engine; which is offset by the SD being more capable of handling higher HP with PROM tuning.
Go for the engine, put headers on it, and get yourself some PROM burning equipment.
Old Mar 8, 2003 | 08:19 AM
kevinc's Avatar
Car: 1982 Z28
Dude, you're fairly knowledgeable and all, but I've seen two unmolested factory L98s from '91-92 and they had 4 VR flat-tops.
With all that hardware you still can't get into the 13.0's...go read a book or something.
Old Mar 8, 2003 | 10:00 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
OUCH!!!!
Old Mar 11, 2003 | 02:37 PM
Well here is the reply from the tech dept. :
" The 300hp TPI engine is emission tested for the 1987-89 Camaro. You
may want a milder cam for the 1991 Camaro. Going from a 305 to a 350
you will need to upgrade to an adjustable fuel
pressure regulator and/ or larger injectors and the chip will need to
be changed to a 350 TPI chip.
regards,
tech "
looks like five7kid was right about the cam......
Old Mar 14, 2003 | 11:42 PM
Aron213's Avatar
Car: 88 Iroc
Not true, Ive seen a GM tech bulletin about the flat tops used in the 90-92 TPI 350 cars. They have a compression ratio of 9.7
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
327IROC85
Sep 23, 2015 12:11 AM
