Finally dynoed my LT1 SWAP!
Old Mar 26, 2003 | 07:17 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Well it's been a LONG time coming but i FINALLY got around to getting my car onto a dyno and tuning it with a wideband! It's a stock block 350 LT1 motor with mildly ported heads, CCXE custom grind cam, 700-r4 with a 3500 stall convetrer, heavy Ford 9" rear and 3.90 gear ratio. The dyno run was made with the torque convertoer UNLOCKED, so I can expect more power once I wire in a switch for it. My Max power was at 6400 RPM and it was 362RWHP. Peak torque was 348. It just feels so good to be able to floor that car after 2 years of building it!
Old Mar 26, 2003 | 07:31 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
that is AWESOME...good job man.
-brian
Old Mar 26, 2003 | 08:39 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Awesome!!! I'll be putting mine in Thursday of next week. Can't wait.
Old Mar 26, 2003 | 09:22 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Sounds like a pretty big cam, or some pretty good "mild" porting, or both. How streetable is it? Nice numbers either way. Makes my wallet hurt thinking about the whole setup though, hehe.
Old Mar 26, 2003 | 11:17 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
It's streetable definately, if you odn't mind poor gas mileage lol. The cam wouldn't pass a sniffer test, it's a good size, but it has GREAT throttle response because of the amount of port work on the heads...they really kept the velocity up on the heads which makes his the most responsive motor I've ever driven lol. The car has a few more Ponies in it when I take it to the dyno and am able to lock up the Torque Converter.
Old Mar 26, 2003 | 11:43 PM
bigals87z28's Avatar
Car: Check The Sig
Hey Mark.. ever down at the pike? Im up here for college, and i sometimes hang out down there... it would be cool to see that monster in person! good looks man!
Old Mar 26, 2003 | 11:49 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Yup, I was just at the Pike last saturday. I usually hang out at the Taco Bell, as most of my friends are ricers. But I do "roll" through the Dunkin Donuts every so often lol.
Old Mar 27, 2003 | 05:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Those are freakin good power numbers, nice job!!!
Old Mar 27, 2003 | 06:39 PM
Car: Check The Sig
cool man.. ill send you a pm
Old Mar 28, 2003 | 12:19 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Nice. Now go take out some of those cocky LS1 owners.
Old Mar 28, 2003 | 01:33 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Finally dynoed my LT1 SWAP!
Originally posted by Markolc
Well it's been a LONG time coming but i FINALLY got around to getting my car onto a dyno and tuning it with a wideband! It's a stock block 350 LT1 motor with mildly ported heads, CCXE custom grind cam...
So all you have done to it is just the ported heads and cam? Or is there more, engine wise that is?
Great numbers by the way!
Brian
Old Mar 28, 2003 | 01:45 AM
Zepher's Avatar
I've heard that higher stall converters actually give you lower numbers. You might actually have 380 or so rwhp.
Old Mar 28, 2003 | 08:01 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Yah, I have a very high stall, and a heave Ford 9" rear with 3.90 gearing...Not ideal for the dyno. Also the runs were made with the TC unlocked.
It's a stock 4-bolt LT1 block with all the bolt ons, mildly ported heads, and fairly stout cam. DFI Managed.
Old Mar 28, 2003 | 11:29 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Damn good #s IMO. Nice work. Weren't LT1s rated just over 300hp from the factory? If so, you have made quite an improvement! Now go out and get some track times! good luck with the set up man
Old Mar 28, 2003 | 03:16 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Great job! Why did you go with the DFI over the GM PCM? Is it more tunable?
How are you going to handel the pukes at CT state emissions?
Old Mar 28, 2003 | 07:37 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
LT1's from the Factory for F-bodies are 275-285 HP...Automatics at the wheels dyno around 235 or so from the factory, with the TC locked up. so I made a 130 HP improveent and have yet to lock up the TC. Guesstimates from me and other serious drag racers say my car should be in the high 11's with the weight of my car (3200 lbs with driver), and the slicks and skinnies I have for it. I'm pumped.
BTW, about the emmissions thing, lol, I used a LPE219 cam to pass emmissions, then one day later I swapped to this cam LOL. I still have over a year left till I'm due again.
Old Apr 2, 2003 | 03:56 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
Markolc : That Cam wouldn't be a Comp XE 230/236 would it ?
Old Apr 2, 2003 | 04:18 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Yup, that's the one.
Old Apr 2, 2003 | 04:30 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
Marlolc : why couldn't you get that one to pass ?
Old Apr 2, 2003 | 04:31 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
Markolc.....sorry
Old Apr 2, 2003 | 04:35 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Much too high of a profile cam on a 112 LSA. The thing still lopes all the way up to 1800 RPM and thats where it is on the dyno. I never tried to go through emmissions with this cam, all I know is all the 4th gen guys can't do it without risking the life of their motors.
Old Apr 2, 2003 | 04:36 PM
N.W. T/A's Avatar
Car: 87 WS6 T/A
Engine: 97 LT1
I have that cam installed, now i'm getting nervous
Old Apr 2, 2003 | 05:41 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Try to find a shop that does emmissions simulations in your area...I know pretty much for a fact that you WON'T pass emmissions with that cam unless you have a tune that you put in while waiting in line to go on the rollers, and you put your regular tune back in right after (it's basically an unstreetable tune). But good luck! I'm planning on swapping to a stock LT1 cam when emmissions rolls around again.
Old Apr 2, 2003 | 11:20 PM
Zepher's Avatar
Hey, have a backup PCM to do this, then no program glitches can happen.
1984HO
Mar 19, 2021 11:59 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
midge54
Jan 29, 2017 07:00 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
