LT1&T-56 swap into a auto car
Old Mar 30, 2003 | 02:38 AM
mess21's Avatar
when swapin in the t-56 do i need the master cyl from a 4th or one from a 3rd gen cause i know i gotta get the cluth and brake pedel set up from a 3rd gen anythin else i sould get while gettin the pedels?
Old Mar 30, 2003 | 08:02 AM
kevinc's Avatar
Car: 1982 Z28
The 4th gen clutch hydraulics are a sure thing, as are the 4th gen pedals. I went that route when I swapped in my T56.
Old Mar 30, 2003 | 09:50 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
You need a 4th gen specifically because it is a pull-type where the 3rd gen is a push-type and would not work with the t56.
Old Mar 30, 2003 | 02:14 PM
mess21's Avatar
sweet thanx for the info
Old Mar 30, 2003 | 03:45 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
So wait, i'm doing the same swap, i was told that i can use 4th gen pedals for the swap. Is that true or can i only use 3rd gen pedals?
Mike
Old Mar 30, 2003 | 05:13 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I believe the pedals are the same from reading info about that. I didn't have that problem as my car was already a 5 speed car.
Old Mar 30, 2003 | 05:16 PM
kevinc's Avatar
Car: 1982 Z28
Mike
From my earlier post:
Old Mar 31, 2003 | 12:47 AM
mess21's Avatar
do u guys know if my 13/4" slp shorties fit on the lt1
Old Mar 31, 2003 | 11:21 PM
TexasLT1's Avatar
Car: '92 RS
yes they'll be fine
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
1nastygta
Oct 28, 2015 08:51 PM
jharrison5
Aug 19, 2015 05:53 PM
cRoe4
Aug 7, 2015 08:46 PM
Leggman1
Aug 6, 2015 04:15 AM
