Help me make my 305 fast cheap.
Old May 27, 2003 | 07:19 PM
itsa91's Avatar
I need someone to sell me something for my 305 to make enough power to stick with a stock 4th gen z-28. I have a TPI 305, so sell me something or give me some advice. Thanks
Old May 27, 2003 | 07:27 PM
Berlinetta82's Avatar
Spend lots of money.
Old May 27, 2003 | 07:35 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
Lets see if I can remember this it's on my local machine shop's wall.......
Fast Good Cheap
you can have fast and good but not cheap and fast.
you can have good and cheap but not fast
basicly thats the way it is. best bang for the buck would be nitrous like a 100hp or 125hp shot(I wouldn't go past that on a old motor) but you risk blowing up your motor if it isn't in good shape.
Old May 27, 2003 | 08:27 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
it's not that hard... the hardest part is planning, and figuring what will work well togther...
pick some budget parts, and do the right machine work... things compliment each other.
rebuild the motor, bring the compression at least a half point higher... if no good aftermarket heads are available on a budget, have a valve job done to yours, and bowl work done to the heads. it will wake them up a bunch.
at that point it's up to camming... 210-220 or a 212/218 comp xe with a 112 lobe sep will both work very well in a 305 and be relativly easy to tune at least priliminarily.
at that point it's getting the trans to hold up, and shift right and gearing..
no matter which way you cut it.. trans, engine, and rear rebuild, retooling will run ya about 3-5 G's to do it allr ight.
all depending on how lucky you get with deals. and reusing parts.
Old May 27, 2003 | 09:09 PM
Aron213's Avatar
Car: 88 Iroc
pick your power adder, but for cheap fun your going to have to run a shot of nitrous to keep up with a 4th gen with your 305...or break the bank and do heads, cam and all the other go fast goodies and then hope.
Old May 27, 2003 | 09:17 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
You need to make at least 170 more horsepower. Unfortuntely there is no cheap way to do it. I ditched my 305TPI for an LS1 swap rather than build it up.
Old May 28, 2003 | 05:05 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I've got three numbers for you.
Three
Five
Zero
Old May 28, 2003 | 08:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Make it as big as you can.... get a 4" bore block, or even a 400 block (4.125") and get a stroker kit...
Cubic inches is the cheapest way to get more power.... and its always a sure thing too.
Old May 28, 2003 | 08:43 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
That's about it. "Go Big or Go Home"
305's are nice but there is nothing like more cubes
Later, Garrett
Old May 30, 2003 | 05:18 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
Three
Five
Zero
nawwwwwwwww
the three words are:
four
zero
zero
Old May 30, 2003 | 05:28 PM
wm_sorg's Avatar
How about some letters:
LS1
Old May 30, 2003 | 06:05 PM
Engine: L03 305 TBI
LS1
dude,
for what it would cost to put a 330 hp, no-torque ls1 in a third gen, you could put a 400 with well over 400 hp and 400 lbs ft torque in the car.
Old May 30, 2003 | 06:22 PM
wm_sorg's Avatar
Unfortunately emissions requirements and fuel consumption spoil the fun.
Lightly modified LS1s run in the high 11's and average 20-22 MPG mixed driving and 29 highway. All while passing the sniffer test.
Old May 30, 2003 | 06:32 PM
Engine: L03 305 TBI
fuel consumption and mileage are primarily a function of induction and heads.
a low compression 400 with a set of vortecs (better yet, fastburns) and a tpi or even an ls1 intake (all you have to do is drill a hole for a distributor) will make way more power than an ls1, get mileage just as good and pass emissions, too.
the biggest difference between gen 1 and gen 2 smallblocks was in the heads. much of that technology found it's way into the latest generation heads for 1st gens.
and first gens bolt right in. all accessories fit.
Old May 30, 2003 | 06:44 PM
wm_sorg's Avatar
You are absolutely right. That is where the LS1 really shines. The flow of a stock LS1 head is usually greater than ported gen I/II heads. They also did a lot with the valve centerline angle as well.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
dutch930
Sep 11, 2015 06:58 AM
st.evel07
Aug 13, 2015 06:15 PM
