bad odder after parked?
Old May 29, 2003 | 08:29 AM
bluepastu's Avatar
Car: 87 vert
When I first start driving (ie shift into first) the iroc vibrates(but not when I shift into the other gears like 2nd thru 5th). Then sometimes when I come to a complete stop it'll stall. And when I turn the car off and open the door - I smell something buring(almost like to smell of old or rotten eggs). I have a new exhaust on it(I'm using the CATCO cat). I open the hood and there is no smell coming up. Then I went over to the cat I smelt it a little bit.
What could it be?
Old May 29, 2003 | 08:36 AM
Guest
Guest
Posts: n/a
check the TV cable make sure its adjuested right. the smell could be your trans burning up. i would get it fix FAST if its the TV cable. i burned up my trans is less then 10mis when the TV cable came off
Old May 29, 2003 | 09:09 AM
Guest
Guest
Posts: n/a
never mind on that.. i just saw then you have a T5
Old May 29, 2003 | 11:51 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Sounds like you are running too rich. Check for codes.
Old May 29, 2003 | 02:20 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
A rotten egg smell usually means a clogged cat. I have the same one you do(Catco) and everythings fine for me on that end.
Old May 29, 2003 | 03:54 PM
Guest
Guest
Posts: n/a
Originally posted by Trans Am#5
A rotten egg smell...
are you sure you didn't fart :-X
Old May 29, 2003 | 05:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check your clutch linkage... it may not be adjusted properly
Old May 29, 2003 | 05:10 PM
Guest
Guest
Posts: n/a
is that the same thing at the TV cable??? i don't know anything about a T-5 trans i only know 700R-4's
Old May 29, 2003 | 07:03 PM
Air_Adam's Avatar
Wait a sec... do you have a mechanical or hydraulic linkage?
If its hydraulic, its adjusts itself, so don't worry about that.
Old May 31, 2003 | 12:36 AM
bes217's Avatar
What the h*ell is an "odder".
Old Jun 2, 2003 | 07:46 AM
bluepastu's Avatar
Car: 87 vert
I have a hydraulic linkage(which is new from GM- master and slave are sold as one piece all ready gravity bleed).
My cat is new(as well as the entire exhaust, motor, headers, cat, mufflers... everything)
It's kill'n me know. I tried looking into it over the weekend and still no answer. I didn't have the motor running because I didn't have it on a lift. Maybe this weekend I can put the car on a lift and have it running. This past weekend I had the car jacked up and just looked around.
Old Jun 2, 2003 | 03:14 PM
91305z's Avatar
I think the rotten egg smell is just the smell from the new cat. The past two new converters I put on smelled the same way for a couple days. As for the vibration I'm no help.
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 11, 2015 05:16 AM
Stryker412
Sep 7, 2015 09:11 AM
Amillionoh7
Sep 5, 2015 11:44 PM
RyanJB
Sep 2, 2015 01:27 PM
