HOW HARD IS IT 2 SWAP v-6 WITH A TPI
Old Jun 14, 2003 | 07:37 PM
90camaro's Avatar
how hard woould it b 2 swap a 6 with a 350 tpi i have all the stuff i need, Engine, Transmission, Mounts, Elect. Fan, Evaporator Canister
ECM, AC & Hoses, Throttle Cable, Under Dash Harness
Gas Tank or Sending Unit, Belts, Misc. Motor nuts & Bolts
Old Jun 14, 2003 | 10:08 PM
firestarter's Avatar
Car: 86' camaro s/c
Engine: 357
Transmission: th350
If your a gear monkey like some of us then i would say not hard at all. Just count on spending about 60 bucks on odd stuff no didn't think of or broke. Other than that its not that hard. Just a guess but i would think a 350 chip should also be in the list unless i glanced over it. Wish you the best of luck. YOu'll love the power difference!
Old Jun 15, 2003 | 12:25 AM
90camaro's Avatar
yea i forgot tha chip included, thanks cause heella ppl that i no says that it goin 2 b hella work
Old Jun 15, 2003 | 12:35 PM
jc33's Avatar
Car: 1992 Camaro RS
Transmission: T5- manual five speed
im just about finished with my swap from a 3.1 to a 350. the worst was finding a clutch to match the v6 trans and the flywheel from a v8. now the headers are burning everything within 3 inches of them. when i first started my plug wires caught on fire. it was pretty exciting burning brand new msd wires.
Old Jun 15, 2003 | 02:27 PM
90camaro's Avatar
was urs a auto or manual?
Old Jun 15, 2003 | 04:21 PM
jc33's Avatar
Car: 1992 Camaro RS
manual if youre asking me
Old Jun 15, 2003 | 09:42 PM
90camaro's Avatar
yea i was, mine a auto tho soo it should b easy then
Old Jun 17, 2003 | 08:48 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Easy" and "hard" definations vary from person to person. Some think a month of evenings and weekends is "easy", as long as you don't have to take out the cutting torch or welder (that defines this swap). Some think cutting/welding is a piece of cake as long as you can finish it in a weekend or two (what it took for the big-block in the '57).
Since you're going TPI, you'll have a lot of harnesses and sensors to change. I did the dash as well, because I didn't feel like tracing down the changes between the two years. Moving the engine mounts on the front crossmember is of itself enough to scare some people away.
Don't assume this is "easy", or "impossible". It's somewhere in between. It's not wise to start it without the entire donor car being available, though, nor to tear things apart without careful labeling and a lot of pictures (do this on both cars, by the way).
gta90
Sep 15, 2015 04:00 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
