2.8 to a 5.7
Old Jul 2, 2003 | 09:11 PM
1SlowS-10's Avatar
2.8 to a 5.7
need some first had experience what all needs change the doner motor (350) is out of 87 Firebird and it's going into a 85 2.8 camaro what all changes need to be made and stuff..
Old Jul 2, 2003 | 09:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Take a picture of the engine compartment of each car. Everything you see in there that is attached to the engine or goes to it needs to be changed.
The ECM under the passenger side dash needs to be swapped, as well as the harness that goes to it through the kick panel (take off the plastic fender liner on the passenger side to gain access to it).
The tranny is attached to the engine - it needs to be changed. The front springs and swap bar are different - change 'em. The engine mounts on the front cross member need to be moved. You might want to consider unbolting the front carriage with the engine/tranny still on it if you can lift the body up high enough and move the engine around somehow in that state.
The tach is different between V6 & V8, but 'Birds & Camaros also use different looking stuff. I don't know details, but the difference between V6 & V8 tach is basically a resistor.
Your best bet is to label everything from both cars as you take them apart, and take pictures along the way. That will be invaluable as you put the V8 driver back together.
Old Jul 3, 2003 | 10:17 AM
1SlowS-10's Avatar
Thanx
wow that's a lot I'm not sure what all I'm gonna through into the 85 from the looks of it the only thing I need is a wire to the coil I not sure how easy it'll be to get the computer stuff in order if anyone has some idea about that it would be apreasated
KO1
16
Oct 15, 2015 05:00 PM
86maro_252
Oct 10, 2015 06:52 PM
LT1Formula
Oct 8, 2015 08:34 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
