A Years Worth Of Work!!!
Old Jul 19, 2003 | 03:45 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
I finally got my new engine done, after a YEAR of building and ENDLESS hassles! It seems like every single part that I bought does not fit. ARRRRGHGH!!! It also took a year because the mechanic that is helping me build it is TAKING HIS SWEET TIME! So here it is, tell me what you think.
Specs:
4 Bolt Main - 355 c.i. - High Nickel casting
Steel crankshaft - Speed Pro Hyper pistons - L98 Rods
Ported Vortec Heads - Edelbrock RPM Vortec Intake - Holley Double Pumper 650 carb - Comp Cams XE 274 Cam - 150 NOS
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Here is a picture of "Old Busted"
Old Jul 19, 2003 | 03:46 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Here is a picture of "New Hotness"
Old Jul 19, 2003 | 09:02 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
Sounds good man. I've been doing mine since oct. of '01 lmao I need to get some money to finish it(anyone feel like donating?). You've got that engine in the car and if so have you gotten it to the track yet?
Old Jul 20, 2003 | 04:54 AM
twiztid dreams's Avatar
Car: 84 Firebird
Engine: 2.8l
nice lookin motor man. ne idea's on output #'s????
Old Jul 20, 2003 | 05:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Me thinks thou hast seen Men In Black one time too often.
Looks good... can I have the leftovers? hehe.
Old Jul 23, 2003 | 11:14 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
ok guys i have a question, why does everyone use the blue gasket maker on intakes?? I alwasy use the orange stuff but i keep getting stupid intake leaks. is the blue better?? thanks
Old Jul 24, 2003 | 05:04 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: A Years Worth Of Work!!!
Specs:
Sounds like a good combo. Did you consider going with the Nitrous grind version of the 274? Everyone is going with the XE274 (and I don't blame 'em after seeing low 12 second passes)
With a 3.73 gear, 26" tall tire and about a 3200RPM stall your motor should throw you well into the 11's
Old Jul 24, 2003 | 05:53 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
I thought all vortec heads have the "aligator teeth" on the front of the head? i know they are vortec heads because of the intake bolts though.
Old Jul 24, 2003 | 08:35 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I actually prefer the black because it blends in better I think. Especially with a black block, its hard to tell its there...
Old Jul 24, 2003 | 09:27 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
For putting on intakes I always use Ultra Black. It's a more high temp sealer than the blue or orange. To keep it from leaking start about a 1/2" up on the head with about a 3/8 bead. Another problem could be if you got the block decked and alot was cut off or the heads surface and alot cut off them to it'll cause problems with the intake lining up and sealing. If thats the case to fix it you have to cut some off where the intake bolts up.
Old Aug 2, 2003 | 03:08 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Thanks for the kind words guys. Anyone have any ideas as to what this might put out??? I just added a Holley 650 Double pumper. Also have Heddman 1 5/8" headers. thanks!
Steve
Old Aug 2, 2003 | 03:16 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
I just got desktop dyno to give me 400 hp at 6500 rpm and 400 torque at about 4500 rpm. I know it's prolly a bit less than that but that is still encouraging, what do you think?
Steve
Old Aug 4, 2003 | 02:33 AM
Air_Adam's Avatar
I'd say prolly 375hp/400ft-lbs... thats W/O the 150 shot.
Old Aug 4, 2003 | 02:30 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
WOW! I would **** my pants if that is true. I certainly hope so. And from the way it sounds when I start it, it just MAY be true! But then again, I also have open headers right now, lol!
Steve
Old Aug 7, 2003 | 05:33 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Read my signature. You'll like it.
Old Aug 8, 2003 | 10:10 PM
MotorCityMuscle's Avatar
Lookin' good bro!!!!
You gotta swing by my place soon and check out my new toy!
Congrats on finally finishing the motor swap, that old 305 was toast. BTW-you ever get those GFX installed?
Old Aug 9, 2003 | 07:54 AM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
when it's all said and done, how much did you end up spending on the whole deal? (If you don't mind my asking)
Old Aug 9, 2003 | 02:33 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Dave - I will definitely swing by when I get this thing legal. What "toy" did you pick up this time??? I never did get the GFX painted and installed, ran out of money and time.
As far as what I spend for the engine, heres a rough breakdown:
4 Bolt Main Block (bored, honed): $350
Hyper Pistons $100
Rods Machined L98 Rods
Steel Crankshaft $175
Ported Vortec Heads $200
Vortec RPM Intake $150
Camshaft $110
Lifters and Springs $80
Pushrods FREE
Headers FREE
Rocker Arms FREE
Valve Covers $50
Oil Pan $60
Holley Carb $125
Misc (Bolts, Gaskets) <$175
Total Around $1575
That's probably low since I just bought a new Optima Battery, all the chrome ****. But I did however get some KILLER deals on parts such as the crank and the heads. My mechanic is always hooking me up with stuff.
Steve
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Streetstuff
Sep 7, 2015 09:23 AM
Fronzizzle
Aug 9, 2015 01:15 PM
