2.8 to 3.4
Old Jul 21, 2003 | 04:46 AM
krallstar's Avatar
2.8 to 3.4
Well into my swap ,here is some of the things i have run into. 3.4 out of 93 camaro. Had to use original motor mounts off of 2.8. Problem tho there was some kind of sensor in the way. The original mount was made to go around this. I think it is the same one that sits on the back of the 2.8 Pass rear head. Having trouble getting that plug out on the 3.4 Everything else sofar seems to be going smoothe. The parts store gave me the wrong oilpan gasket so that stopped my install from progressing. Motor still on lift hopeing to get it in today. Question ? I am planning on takeing the old sensor that came out of the 3.4 block and match one up that has the right threads and size maybe from a different model? WEll maybe I can cut out the mount where that sensor goes just enough tho clear, Then extend the wire hareness to meet. Suns up Going out to play. Steve
Old Jul 24, 2003 | 10:52 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
if you don't get any replies try posting this in the v6 forum or even maybe PM'ing KED85, he seems to be the goto guy with the 3.4 swap
86maro_252
Oct 10, 2015 06:52 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
usafirebird
Sep 29, 2015 11:58 PM
92projectcamaro
Sep 29, 2015 07:07 PM
spartanreaper
Sep 25, 2015 07:22 PM
