L-98 with carb,and mech.fuel pump?
Old Nov 11, 2003 | 07:53 PM
FandGbody's Avatar
Car: 91 rs,83 monte SS
Engine: rs 305,SS 355
Transmission: rs 700r4,SS th350
i have a 91 rs w/o an engine and tranny,that i want to make a cruiser out of.i bought an L98 with a bad cam to put in it.does the stock roller cam have a lobe to run a mechanical fuel pump?if not,and i swap to a regular cam,what else will i have to change?if i keep the roller cam,will i have to change the distributor drive gear?any info will be apreciated.rob
Old Nov 11, 2003 | 10:17 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
your 91 rs should already have the fuel pump in the gas tank, not on the block like the older style engines
Old Nov 11, 2003 | 10:22 PM
FandGbody's Avatar
i forgot to mention,the fuel tank was also mia when i got the car.i picked up a free one from an 82'camaro,and thats why i want to run a mechanical pump.
Old Nov 11, 2003 | 11:01 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
you could always run an aftermarket electric fuel pump, thats what I'm doing with my '84, I'm putting a '90 350 in it
Old Nov 12, 2003 | 02:46 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Does the l98 have provisions on the block for a fuel pump? Either way the stock roller cam does not have the lobe for a fuel pump. If you want to go cheap get the pump form a TBI car and a 3 port regulator.
Old Nov 13, 2003 | 02:21 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
i converted my L98 to carb and i tried putting in a mechanical pump but it didnt happen. i got a blue holley 14psi electric pump w/ APFR and mounted everything in the engine bay. pretty easy, and now i can service everything under the hood. the kit cost me $110
Old Nov 13, 2003 | 03:56 PM
FandGbody's Avatar
let me ask you this,what did the conversion from tpi to carb do for power?also,what is apfr,and where can i get the kit?did you change your hei distributor gear?
thanks everyone for the input.
:hail:
Old Nov 16, 2003 | 02:17 PM
Engine: carbed L98
:hail:
havent drivin the beast yet, will soon though
afpr = adjustable fuel pressure regulator. good for when you get a new carb and you need more fuel pressure (better than buying a new pump again)
i got a whole new vacuum advance distributor from a buddy
Old Nov 17, 2003 | 07:51 AM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
You mounted the electric pump under the hood? Once you take the car for a test drive, could you possibly monitor the fuel gauge (with and without a load) to see if it drops at all, and tell us how it delivers being so far from the tank?
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
