Engine cleanup over the winter, tips?
Old Jan 3, 2004 | 08:09 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
Hey guys, im taking the engine and tranny out of my car over the winter and im just wondering what i should be tuning up or replacing or whatever. Im changing some gaskets and seals, painting the block, and just doing some check ups. Anything else that should be done? Anyone ever just taken thier engine out and fixed it up a bit?
Thanks!
Happy New Year everyone!
Cam
Old Jan 3, 2004 | 09:19 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
woah, that sounds kinda like what im doing.
I been cleanin an engine to go into my trans am. Im using spray on engine cleaner and a lil wire brush that looks like a toothbrush. Since the hose is frozen im using buckets of hot tap water to rinse it.
The winter weather presents some unique challenges.
If i can im going to bring the engine inside to paint it.
Old Jan 5, 2004 | 10:50 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
You guys pullled your motors just to do cleanup etc??????? Now that is what I call dedication........ Or, is it "boredom"?????? LOL
I am happy to see folks that are so motivated to make thier cars more than just a "transportation tool"....
Have fun guys.
Old Jan 5, 2004 | 11:15 AM
pskel350's Avatar
i pull my engine every winter, just to check things over, and just to clean everything up. i always replace hoses, gaskets, and a basic tuneup, and anything major that is a problem.
Old Jan 5, 2004 | 11:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
ditto on pulling the motor every year to check it out....
it's what racers call "rebuilding" time....if the motor lasted all season then it's time to really check it out for sure. There's been winter projects for me every year in the quest to go faster and learn more.
Old Jan 10, 2004 | 05:37 PM
Car: 1984 Z28
Do i need to take the intake manifold or the distributor out to pull the motor? and is it easier to take the tranny out with it rather then unbolting it then just pulling the block?
Old Jan 10, 2004 | 09:55 PM
pskel350's Avatar
i never take the intake off when i pull the engine. but i always take the distributor out. with a t5, i always pull the tranny, and leave the bellhousing attached. but you can pull the tranny with the engine also.
Old Jan 10, 2004 | 09:57 PM
pskel350's Avatar
i also chase all the threaded holes in the engine and heads when i pull the engine. just to make sure the bolts go in easy, and without debris in the holes
Old Jan 11, 2004 | 12:22 PM
Ya, i just got my engine out yesterday. took it off with the bellhousing attached, just like that.
Old Jan 11, 2004 | 12:24 PM
heres another pic
Old Jan 11, 2004 | 12:25 PM
and my car without an engine.
Old Jan 11, 2004 | 09:11 PM
Car: 1984 Z28
That is a pretty greasy lookin engine you got there. What are you going to do to it? just clean it up or add some performance stuff to it.
Can i use one of the bolts that holds the waterpump on to lift the engine out. I mean to hook the chain to it?
Old Jan 11, 2004 | 09:15 PM
Im not doing anything with that engine. my brothers gonna use the heads.
Im putting in a newer slightly less bagged engine. I painted it chevy orange! and im replacing the clutch disk...
Old Jan 11, 2004 | 09:17 PM
Car: 1984 Z28
why dont you throw some performance **** on it?
Old Jan 11, 2004 | 10:46 PM
I would really like to...
Id rather put it back together with headers, but im poor and unemployed. This is a budget job to get me rollin again
so they (ick) exhaust manifolds are goin back on. I am gonna chop the cat off tho...
Old Jan 12, 2004 | 03:07 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Re: Engine cleanup over the winter, tips?
Originally posted by 84Z28_5.7ltr_V8
Hey guys, im taking the engine and tranny out of my car over the winter and im just wondering... Anything else that should be done?
Don't forget to clean up the engine compartment, not just the engine. Spend a weekend cleaning and painting everything under the hood so when you put the engine back in- it all looks like new.
Old Jan 12, 2004 | 03:14 PM
Yea, i just put a whole can of white trem clad paint in the engine compartment. it needed it too.
customblackbird
Aug 15, 2021 10:16 PM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
tecustomz
Aug 16, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
