327 into '91 RS
Old Feb 16, 2004 | 12:13 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
327 into '91 RS
I'm getting ready to swap a '68 327 into my '91 RS LO3 (blown up). I'm gonna use the factory TBI induction (for now) with the 327 short block and new heads so I can bolt up the accessories as the '68 heads don't have to correct bolt holes. I think we have worked out most of the little details of this swap, but what am I gonna do with the knock sensor? Is there anything else I should be aware of before getting started?
Old Feb 16, 2004 | 05:14 AM
ede's Avatar
ede
why don't you put the knock senser in the same place gm puts them? or are you wanting to eliminate it?
Old Feb 16, 2004 | 12:55 PM
cdartz's Avatar
I think a good question would be whether or not you should use the knock sensor for a 305 engine, or a 350. They are not the same part number. I'd research what the difference is between them, and what would work better with your 327.
I'd also buy some PROM burning equipment, since your engine displacement doesn't match any stock PROM.
Old Feb 16, 2004 | 05:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why not just stop and the jukyard and pick up a cheap carb and manifold for like $20?
Old Feb 16, 2004 | 10:17 PM
RSFreak's Avatar
That was basically my question, can that be done on a '68 block? The engine is still in the donor vehicle so I haven't gotten to take a good look at it yet.
BTW, the TBI is only gonna be temporary 'til I decide which way I want to go as far as induction (and cash outlay!) so as long as it runs at all, since the 305 is toast, I'll be happy.
Old Feb 16, 2004 | 11:23 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The knock sensor just screws into the original block drain hole. All you'll have to do is unscrew the plug and screw the sensor in. I was using the original LG4 knock sensor on my 327 before I went non CCC. Had no problems with it.
Old Feb 16, 2004 | 11:56 PM
RSFreak's Avatar
Thanks man! That what I needed to know.
Old Feb 17, 2004 | 12:16 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
You use the 350 knock sensor & ESC module because the bore size is the same as the 327.
84 TA NV
Sep 6, 2015 08:02 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
92zeddar
Aug 26, 2001 08:19 PM
JC88Camaro
Sep 22, 2000 12:55 AM
